Anyone buy iPhone XS from HK/CN ?
eric16
Still some savings . I read somewhere that people buy from resellers ? From China ? Cheaper ?
Sent from 你怕黑吗?黑有什么好怕 using GAGT
Some smaller resellers in HK sell iPhone XS max cheaper than Apple store, but because there’s very little documentation control as they only issue their own store receipt, I don’t dare buy from them. And it could be slightly used set as well, many unknown factors.
Some of these smaller resellers really ah beng shop, scared kena whack.
You can check out price.com.hk to find out which shop sells the cheapest iPhones or even other electronic items. Good site to compare prices between resellers. They have an app too
tamago_
Deluxe Member
u can walk in any apple store in the world to get it fixed.
Service centres outside HK and China might not replace due to unavailbility of dual SIM XS/XSM in their inventory, or ask you to acknowledge that they will replace the unit with a non-dual SIM unit.
eric16
Is the local set Sim tray same as China/HK set Sim tray that can put in dual Sim?
No lah, the local SG SIM tray is the same as all the past year’s iPhones, but the HK/CN SIM trays allows u to put 2 nano SIMS back to back on the same tray. And there’s a special plastic clip for the bottom SIM card to prevent it from dropping out when u invert it upside down .
mrtanbg
Is HK side the cheaper place to buy apple stuff , even when we compare with Changi airport without the gst?
monsters2009
The answer is no.
If the answer is yes then this thread won’t exist
I thought they could share the same sim tray design...but only do the trick via software to enable the esim/physical dual sim.
eg if you put 2 sims back to back on local set, the software will not recognize.
Tyrian
u can do simple maths here
let's take the XSM 256gb for example
SG sell for 2039
HK sell for 10799
Convert HK 10799 to SGD is 1894.56 (take SGD 1 = HKD 5.7)
take SG without GST is 1905 (2039 / 1.07)
as u can see, HK set sell quite close to SG without GST. difference is about S$10. unless u need the 2 x physical sim, no point getting the HK set.
and i believe HK got no GST so there wun be GST refund.
mrtanbg
SG sell for 2039
HK sell for 10799
ok thanks. The price differential not that great.
sendhalp
Did some reading, and found that, one of the reason why China, Taiwan and HK doesn't have e-sim is because, china's resistance to e-sim, (but china telcom had launched e-sim earlier this year.
https://www.forbes.com/sites/bensin...-rest-of-the-world-isnt-getting/#6486d32f6a43
I'm pretty interested to get a hk XR just because of the dual SIM, otherwise does anyone know if we can buy from apple.com.hk and then ship to Singapore?
obichacha
Have any forwarder to ship it from hk?
I found that Vpost got china address only.
Last time the boderlinx has hk address, but died already.
Habrosus
My target is iPhone Xs Max 256MB with physical dual-SIM capability.
How best to get a brand new genuine set? Great if we can get a forwarder to ship it over, direct from Apple HKG. Anyone's found one yet? :o
josephkjc
Don’t forget there might be GST charges imposed by singapore customs when shipping from HK.
