AMD Ryzen NB Discussion| Lenovo Thinkpad E495/E595/T495/X395 Well-rounder performance CPU + GPU
archonmage
Review on Thinkpad E585
For those who has bought the E585,
Can you share how is it, pros and con for it ?
Thanks,
archonmage
stillgottheblues
Thanks,
archonmage
Cons:
- Screen is not as good (sRGB, Adobe RGB and brightness)
- Software got some quirks (they have emailed 2 updates which I have not applied yet)
Pros:
- Very good keyboard (same as my 3k laptop)
- Windows precision touch pad
- Charges very fast
- Speedy
- Not noisy
- Build quality (though not as good as the better ThinkPad)
- Very easy to upgrade/change components
Taking into consideration its price, it's a good buy definitely. If you want better, just pay more for other series or brands.
archonmage
Cons:
Pros:
- Charges very fast
- Speedy
- Not noisy
Thanks for the review ^_^
Can I know what are your configurations?
stillgottheblues
Ryzen 7, veges 10, 512GB SSD, 16GB RAM, FHD screen, 65w charger, something like that. Lowest price for this specs on market already but with decent built quality.
Cons heavy la, if use at home ok la
Cons:
Pros:
- Charges very fast
- Speedy
- Not noisy
archonmage
Wow, that are some serious configurations.
Getting a basic one since it is for my kids,
Ryzen 5, 8GB Ram, FHD screen, 45w charger, 1 Tera Hdd,
All in, $690.
With the 3 year warranty thrown in, it is a good buy.
batniss
2.1kg for E585, and 1.75kg for E485, which is slightly heavier than most non-gaming laptops.
To put into context, Macbook pro is 1.83kg.
The weight is not accurate for e485.
Mine comes without hdd and only a single ram already >1.8kg.
Potential buyers u might want to include this into your consideration
GrandJedi
All in, $690.
Its not 690... 735?
stillgottheblues
Have to pay more to get better and lighter laptop, or get HP version of Ryzen. Maybe that's the trade-off or else those light laptop will have no USP.
stillgottheblues
Thanks for the advice.
I have consider it too. But finally decided on the hdd
HDD will be slow and will get slower as time goes by. I don't know why it's happening on Windows whereas on the Mac and linux it does not seems to have this problem.
LegendZenify
All in, $690.
Why didn't you opt for the 65w charger?
It's just +$2.:s12:
