4K Monitor Recommendation
Matrix23x
Hi all!
Need some recommendation on 4k monitor
should be looking at about 27-28 inch or so
budget about 400-600
i saw the newer models without bezels :love: looks gd for multiple monitors
Any advice on the P270 by Prism+ ?
i think i saw someone mentioned they are korean oem made panels? :s11:
TIA! :o
singupingu
Your budget already dictate you to go for Prism and Supersolid you don't really have much choice. Both brand bring the same Korean OEM model I believe, with slight variation only between them. Tech Show they got booth. Go check it out personally perhaps.
Either way, it's better than buying from Qoo10. Coz warranty is covered locally, any issue they will cover you. Where as if you import yourself, any issue you suck thumb.
Sent from OnePlus ONEPLUS A3003 using GAGT
Matrix23x
i was wondering if those korean oems can last anot, while on the side note was considering dell 4ks but then no bezels...
royfrosty
Go for Samsung U28H750 man.
Its a good buy at $568 or less.
Comes with quantum dot display, 60hz freesync.
royfrosty
This one is TN panel unfortunately
Doesnt matter really. Not all TNs are bad. Is how well the display performs. This TN panel has a 170deg horizontal viewing angle and 160deg vertical.
Honestly go down take a look. Its really not as bad as you think.
If use for non gaming and occasional non gaming ok Ma?? Best bang for buck? Sian dell monitors not in the show hor
hlots123
but kiv 170/160 this spec is commonly quoted for TN, tho...
tftcentral.co.uk
pcmonitors.info
lifeishard
purpleberry
Ok, will have to visit sls to take a look.
