Speedtest Discrepancy
uncle_josh
Anyone encounter when doing speedtest,
1. Using Windows 10 OS and Edge, results is very good
2. However , if use Windows 7 or Linux with IE, Chrome or Firefox,
Results looks like this :
Currently on Starhub, 1Gbps plan, wired connection
dryteletubby
use iPerf to test instead.
Internet speed test for me never seem to give the same results twice.
Maybe test by downloading a game on steam? If it maxes out your bandwidth, your internet should be fine
eric3743
http://www.speedtest.net/result/7776738979.png
http://www.speedtest.net/result/7776737844.png
For Windows 7 could be Flash issue especially for download around 300mbps.
Try to use their (local) Speed test and refer to my result on Windows 7 & Chrome.
http://starhub-broadband.speedtestcustom.com/result/458ac530-e191-11e8-9e1d-1da631bc7ac5
While using Ookla speedtest application on Windows 7
https://www.speedtest.net/my-result/d/020aba18-e9ae-456f-9ec9-28c4f44de566
Since iperf requires two computers, so you install the server on one computer and then the client on the other computer, right?
If using public iperf server, then the speed will depend on the public server just like Speedtest.
uncle_josh
iperf seems for internal network speedtest to me. Isn't it?
2x pc, 1 as server and 1 as client.
I have no problem running the speedtest from Starhub website.
If I can get Windows 10 and Edge to get that kind of speed, I don't think is Starhub issue.
(If you open the link at the last line of post #1)
Just wonder anybody encounter this descrepancy like me. Haha.....
Of course any expert can describe the descrepany , that would be much appreciated.
uncle_josh
Under Microsoft Edge, my Adobe flash player was turn on. Wouldn't it be affected also ?
xonix
In my experience, there is a slight difference ( not huge ) when running SpeedTest between HTML5 vs Flash environment.
uncle_josh
You are so lucky
You can see mine post #1 is huge diff
Sent from 当断不断, 害人害己 using GAGT
eric3743
Microsoft Edge may use different Adobe flash player version from Windows 7 Chrome.. &or may run differently, not sure.
It is said that due to a particular Adobe flash player version.
My earlier post speedtest.net result from Ookla is using HTML 5 as standalone application without flash on Windows 7.
This result is on another laptop on Windows 10 Home with Microsoft Edge.
http://starhub-broadband.speedtestcustom.com/result/a17b8790-bf26-11e8-8d0d-4303b9ddbd8d
