Custom car decal/sticker/wrap in Singapore
datsthebax
Was just wondering where is the best place in sg that I can add some cool "Lines" to my car
Need to give it that sporty look
Also, anyone know where can customize care sticker/decal to paste on windscreen?
Please advise tq tq also help share and ask around thanks
EJB
It'll be hard to wax thereafter... and if you meet somebody itchy hands tear the edges....
myviowner
Anything that stick on surface will come off eventually.... Get over that "sport look" phase bro. lolzx
The workshop cant tell you how long it will last though....
AL5509
Does it peel off?
It a sticker, so why dont it peel off?
Unless you love your stickers soooo much, you can consider to stick it then spray lacquer(over) it.
It will stay on there quite permanently.
Means you cannot tear it off too.
TheBaldMan
Wrapworks.For stripes and wraps.
Supermodern.Gemokstickers.JJ. - Custom cut decals and stripes.
Places i have gone to for customs and am happy with end products.Prices vary from high to reasonable.
ureshine
Burlington Square(print shop facing main road) can customize car decal. I did once before
HellHunter
All can do if you're willing to pay :o
Check this shop out, they used to be good back in the day but they've gotten quite a bit more popular. Prices likely gone up and workmanship likely a little down but you need to gauge for yourself if it's gone to their head.
SGC AUTOGRAPHICS & SIGNS
#01-268/270, 3015 Ubi Rd 1, 408704
6844 6260
http://sgcautosupply.com.sg
Map:
https://goo.gl/maps/PP2sbaWuwcB2
HellHunter
How long can it last?
A number of factors determine this. Just a few below as examples:
-quality of the job done(pre-application prep of the paintwork/surface is extremely important)
-quality of the wrap/sticker/decal itself
-how abrasive your car wash is, with decals done best to wash yourself and be gentle on the decal parts, gently washing from the middle of the decal outward in a circular motion is best, imo. Never pressure hose the area for too long or directly if you want to prolong its life.
-is the car parked sheltered or exposed to the elements
-etc
-etc
-etc
Some, if done properly and taken care of, can last years.
datsthebax
What's the difference between wrapworls those who do custom cut decals and stripes
datsthebax
When it peel off does it come off clean or will it leave marks and affect paint work of car
-etc
-etc
-etc
HellHunter
This largely depends on the quality of the sticker, how long it's been left on etc. 3M and other brand ones come off clean. Some cheaper ones or those left on for longer will likely leave a glue residue shadow but it's not permanent damage, can polish out quite easily.
TheBaldMan
Wrapworks built up quite the rep. for wrapping in general.Of the body.Grills.Etc.They have top grade quality materials such as 3m oracle and a bevy of cool colors.After service also is gd.
The others you can do wraps.And also get them to custom cut your decals that you want plus install.The ones you wanted for your windscreen and racing stripes.And cater to very small projects starting from a few dollars.
They are cheaper then wrapworks in general.
Depends on your scale of your project.There are many shops nowadays.But remember if you gonna budget for total wrap,it will be a hassle during removal.With all that residue and all.And quality wise will be largely unknown.The other inputs so far by hellhunter accurately tell you of the qualities u shd chk out for.
