Xiaomi Android TV Box discussion II [consolidated]
bunegg
Anyone got problem with the volume / loudness after updating the box to 8.0?
All my apps now become very soft.
As Mr Choo mentioned before, supposedly the Oreo updates have been pulled by Xiaomi. So did your system prompt for you to update?
Ref: https://www.reddit.com/r/AndroidTV/comments/9r993j/cant_update_mi_box_3/
https://www.reddit.com/r/AndroidTV/comments/9oedf2/oreo_update_not_showing_on_mibox/
The above two links say Oreo updates have been pulled.
All kind of bad comments to Xiaomi with regard to Oreo update. Some say factory reset will fix majority of the problems. Have you tried that?
Charlie_Zhan
yea the oreo OTA update was withdrawn but Xiaomi released the OTA update again with the new latest updated firmware a couple of weeks back.
ice_angel
Mi Box 4 is not Mi Box S.
Mi Box 3 is not Mi Box.
Only Mi Box and Mi Box S (Global Version ) are using official Android TV OS certified by Google and has official Android TV version of Play Store.
Mi Box 3, 3c, 3 Enhanced, 4, 4c are for mainland China market and they do not have Play Store and no certified DRM to run Netflix HD even if you manage to install mobile phone version of Google Play service/Play Store. They also have quite some advertising which you need to root the box to get rid of. Do not buy them for use here. Actually by Chinese law, they may be required to update FW to get rid the unauthorised apps (but probably not really enforced strictly).
Same goes to Mi TV. Worse is that there is no way to root as of now and no easy way to install Google Play service on Mi TV.
Just surprised by the Lazada seller who advertised Mi box s, keeps saying his product is "top box 3" (I assume he means mi box 3). I messaged him privately and he said the same thing.
That is the confusing part. Better ask him the exact model number, supposedly Mi Box global version is MDZ-16-AB and Mi Box S is MDZ-22-AB.
gregory_choo
may be you should try to message to him in chinese.
BiggieZee
So today I've bought myself the mibox global version mdz 16ab model dat comes with UStype 2 pin plug. Issit safe to use with an adapter on the wall electrical point? I compare the plug with other safety mark plugs here n saw that there's a bit difference in the amp n voltage. Just want to know before i plug it in. Thnks
Charlie_Zhan
I'm using the US 2pin plug directly plugged into my power strip.. it's written on the plug that it accepts 110-220v.. means no transformer required
bosscaster
I sideloaded TVB Anywhere APK onto Mi Box, and was able to run it. However when I tried to play any video it will return an error.
It is designed to run on mobile device only.
Much appreciate any advice on how I could get it working on Mi Box
gregory_choo
is there a casting option? if yes, chromecast it to mibox.
https://www.tvbanywhere.com.sg/faq.html
It mentions that TVB Anywhere does not support TV boxes. Looks like they detect the underlying OS and block (official) Android TV OS.
Hidetoshi
looking at the last few pages of comments, seems like xiaomi box has many problems...
do you all suggest apple tv or Nvidia shield?
Charlie_Zhan
tbh the mibox is working pretty fine for me... if you really have the cash to burn or the need for a shield tv, go for it.. otherwise a mibox will most probably be perfectly sufficient... no comments on the apply tv...
it's two different o/s and device.. and popularity in terms of price and value, the apple tv just isn't worth it. at least in SG context.
gregory_choo
xiaomi box - china version has many problems.
mibox international version is very good.
Hidetoshi
I am currently having a non digital ready TV. If i buy the Mi Box S, do i still need to get another Antenna + Digital set top box? I am confused
Charlie_Zhan
media server/streaming box is a seperate issue from digital tv tuner/antenna.
Vader
Help, my Xiaomi TV box has no WiFi. The option to select is there but its empty.
