What is the width of computer desk needed?
Alexls
I have a 50cm width desk and using 27 inch monitor on it is damn uncomfortable
27 inch monitor need how much width? U all table how much width?
yusoffb01
length not width. need a huge one for what? your monitor using side stand?
shadow84
so is the... depth problem.. not width
u rotate table 90 degree
Then his little brother will be hitting the table legs? lol.
Im using a 80cm depth table and used a 27" monitor before. Still looks okay, slightly small. Now 32" is just nice but cant go too near to it.
Anyway, when looking at a table from top view, you can call it width. But looking at it in 3D or in the real world, its called depth of table.
UptheToon
mine is about 80cm... comfortable and a lot of space on the table to keep junk stuffs...
Alexls
Slightly small refers to what? Monitor or table
shadow84
27" Monitor seems slightly small when i sit at about 80-90cm away from the screen. For a 32" monitor at same dist of 80-90cm, it feels slight big coz i have to turn my head just a little to see everything. But for 27", should be fine coz everything is within your eye's vision.
alamakazim
actually hor... TS problem is what ah
"damn uncomfortable" of what ... the arrangement or ergonomic or viewing distance
_dXter
Dont use too big. Personally, 27" too big for that depth. Have a 80cm depth table, used to have 27", reduced to 24" more comfortable for viewing.
ragnarok95
Senior Moderator
Senior Moderator
What width? You mean the distance between your eye and monitor?
Everyone have their own preferred distance. You test yourself you should already know the distance you are comfortable with right?
Once you have that distance then you adjust or decide yourself.
miketkf
I have 3 computer desks of different lengths.
1) The length of 1m. is use for 2 Synology NAS.
2) The length of 1.4m. is use for my PC with Nvidia Graphics Card
3) The length of 1.4m. is use for my PC with AMD Graphics Card
12122012
my table is 150cm by 70cm just nice for my 27" monitor. viewing distance about 80-90cm.
nwh_sg
if you can install a sliding keyboard+mouse tray underneath the table, then you can increase the viewing distance by the width (or depth) of the keyboard drawer.
