- Dec 27, 2007
moi highest speed that I was able to hit with the 86U!
Did some tweaking with the settings and this is the speed I got about 1-2m away from the router
Can share what u did with the settings?
Thanks
I see u compare this with orbi. How big is your house?I think this setting plays a important part
multicast rage: OFDM54
correct me if I’m wrong. No network expert here but just tweaking from what I researched
I’m skeptical that this could benefit me more (in terms of range) than orbi for my mansionette. Even with orbi I’m still getting one dead spot.
Does this ax88u have the range of 2 orbis?
Agreed. A piece of good equipment. I am looking forward to the AX6100 to setup my second network
It depends on the size of your house and also, any obstruction along the way.
I still faced poor signal at far end of my house which is a old 5-rooms but nevertheless, the range is slightly better than my previous AC87U
Unfortunately mine is a 2 storey flat and unlikely a single router can cover top floor completely.
Stuck with my orbi then. Unless there's other better setups.
AiMesh! But if your current setup works then don’t change bah!![]()
Problem is I only have laptop, no desktop xD
Wow so just 1 on its own and coverage enough over the velop?Using the router for last 2 weeks. Working like a charm. Big upgrade from the previous setup of AC87 + Linksys Velop. Using this in a 5room HDB flat.
Why choose this when there’s ax92u?Wow so just 1 on its own and coverage enough over the velop?
I am thinking whreht to try to swap from my existing orbi
Sent from Samsung SM-G975F using GAGT
Cheaper and less units around the house.Why choose this when there’s ax92u?
Worth to consider. I switch to AX88 also coz there is only one set required, rather than 3 velop in home. I also believe Velop does not really improve the speed of the internet, just extend the range. I was getting between 30-80mbps in my bedroom. Now I can get 120-150 mbps average using AX88.
