Starhub 1Gbps Fibre Review
sk1609
now test result:
speedtest.net: download 584 upload 516 (me <--> Singtel)
speedtest.net: download 314 upload 514 (me <--> Starhub Mobil Pte Ltd)
broadbandspeedtest.starhub.com: download 910 upload 946
Why results is different?!
uncle_josh
same issue as well. now getting connected , no internet issues router wired and wireless same problem these past two weeks. cannot even surf and load youtube front page,not even playing video.Internally my devices can each other just find , while streaming movies from my NAS.
starhub really sucks
Streaming movies from your nas has nothing to do with starhub !!! Its your own internal networks.
Sent from 当断不断, 害人害己 using GAGT
uncle_josh
See, it gave you cancer also.
Haha...
If wired/wireless also having issue, then check direct ont.
Anything beyond ont is either user/device issue.
why jump to conclusions ?
OKorNOT
Starhub 1 gbps fibre got give free mobile sim card for data?
Singtel sux their router is faulty just after my contract ended...somemore price also more exp den others...goin to cancel soon
You can buy your own router for SingTel.
If you are going to switch, then M1 seems to be better if you need the free mobile data Sim.
Ref: Starhub free router offer for 1Gbps plan at S$39.9
http://www.starhub.com/personal/sto...band--3990month_1000mbps-fibre-broadband.html
M1: 1Gbps plan with free router and 512MB mobile Sim data at S$39
https://www.m1.com.sg/fbbtnc
SingTel 1Gbps at S$44.9 and 512MB mobile Sim and free SingTel WiFi
https://www.singtel.com/personal/products-services/broadband/fibre-broadband-plans#SITEX20181
OKorNOT
Do starhub have weekend installation...
I know m1 sure dun hav
At least the other 2 telco give u proper brand router...
My friend who recontracted with singtel few mth ago say singtel changed router for their fiber,but it still some ** brand tat probably most nv heard b4...
Charge higher den others nvm but still cant provided a proper brand router for their customer, no way i goin to recontract with singtel
eric3743
No free SIM card for Starhub 1 Gbps fibre unless you opt for HomeHub package.
Why don't contact Singtel on your recontract & router based on your subscriber detail to find out any better offer.
dryteletubby
M1 does have weekend installation but it cost more.
I personally will not use the ISP router. You can get them cheaper on carousell.
Charlie_Zhan
don't bother.. SingTel will still give you their ** routers which are restrictive as hell. it has decent speed and range for a small hbd flat which is totally fine for most average consumers, but if you are anything beyond an average consumer, it's router webui and restrictions will give you last stage terminal cancer. so end up you paying higher monthly subscription + need to fork out another $200-300 for a good router if you do not already own one.
Charlie_Zhan
StarHub gave me the Linksys EA7500 router which I took up their free 2 years 1gbps fibre bb offer earlier this year.. I tried using it and it was actually quite good...
so end up I used it as an AP instead.. :s13:
eric3743
Linksys EA7500 is good & stable when i did the review and act as an AP to 868.
No issue and speed looks better than 868 on wireless.
Stiletto
My Starhub 1 gpbs only gives me 500mbps+ at speedtest. Is this normal? This is after trying out many times throughout the day. I am connected using a CAt 6 ,ethernet cable, from the ONR to my PC's gigabit ethernet connection.
deathblade82
What browser is this ?
eric3743
