Honda Fit/Jazz Part 2
HondaJG
did anyone upgrade their iRoad SD card? understood it has to be class 10.
can share what capacity size did you purchase? where did you purchase and the price? :s12:
Fuzzylogic88
Honda Jazz 1.3LX
Hi all, anybody has got good recommendation for the rims for honda jazz 1.3LX, am thinking of changing the stock rim? Thanks!
iCubes
I recommend using Sandisk microsd cards. No issues with my dashcam so far (2 years and running), i got it off lazada.
CCCustom
Ironically, if you go through the cam threads, you will find that most people with card problems were on Sandisk, and their problems went away after they switched to other brands.
iCubes
The guy who installed my dash cam told me to avoid Samsung so I went to the next big brand Sandisk. Oh well.
HondaJG
which brand and card capacity you purchased?
iCubes
what is the card capacity you purchase?
64GB. I went for a fairly large one because I believe a larger card will have fewer write cycles(erase and write) and therefore a longer lifespan. I might be wrong on the theory but its working out for me. Anyway i always keep a spare so if it fails I can replace on the spot.
Jingpong
Hi guys ,
Im waiting for my new Jazz 1.3 LX. Intend to change the 15 stock tyre and rims to 16 . Any recommendations on the workshop and specs ?
Or anyone have the lobang to get the RS black rims ?
Thank you !
StanII
Hi guys ,
Thank you !
carousell if you dont mind used.
