Singapore Savings Bonds
CCPie
thanks.
shucks means i missed december's one.
December's ssb seems better than January's ssb in terms of long term.
January's ssb avg only win December's ssb avg for first 2 years. Or maybe i should just pump more money in and one year later redeem. Is this a sound decision?
Can someone explain this? The ssb not the same each month is it?
compro_1975
seems like monthly there is an increase in the interest given? where can i find he historical chart ar?
havetheveryfun
it may increase or decrease, it fluctuates quite a bit
chart would be if someone is free enough to plot, probably some bloggers out there might be doing so
but you can track back and check all the past month's interest rates on the SSB website, under "Announcements", as every issue comes with a press release
AvatarViper
let's say i have $50k to put into SSB. Is it 100% guaranteed that the full amount is going to be allocated to me?
banyan8
How long does it take to top up SRS?
Got to top up by end of the year. But don't want the fund sitting idle there since SSB is only available in a couple of month. Which is the last date to top up? :s8:
BBCWatcher
It should be possible to top up your Supplementary Retirement Scheme (SRS) account as late as December 31 at some hour, but I wouldn’t cut it that close if you can avoid it. If the plan is to put the funds into a Singapore Savings Bond — not my first choice suggestion unless you’re late career — then those funds will be idle a couple months since the first SRS compatible won’t be issued until March 1, as I understand it. A couple more days of idleness won’t significantly matter.
Globe
if i buy say $20000 worth of ssb , is the deduction immediate .... i can't remember.
or they only deduct when i get the allocation the following month ?
eg , i got $15000 in the bank but want to buy $20000
limster
answer is clearly stated on the SSB website. apart from regular cash, they even put up the answer for SRS funds as well.
kennethtbh
Deducted from the bank acct immediately.
banyan8
Thanks for the info. May I know what your first choice to utilize SRS fund? I am also thinking of buying some ETF when the market crashes next year. How can I park my SRS fund before the SSB becomes available?
cal3135
SSB application n redeem fee is at $2 per transactions.
I find This acceptable; I am able to process all transaction online.
This save on transport$ n time
finale1
Short Term Interest Rate inversion
Above Eurodollar Yields.
Nearby yields all inverted.
Will we see SSB offering inverted yields as well?
