2018 Google Pixel 3 and 3XL...πŸ˜—πŸŽ‰πŸ˜΅
swgj86
Probably looking at the pixel 3 price not XL
How come RWM selling Google 3XL so good price?
Sent from Where Is My Nexus5x using GAGT
laughingPANDA
Looks good bro. There is a 101 things that can go wrong installing a WSD haha. Painful luxury
Hahah bro I was like **** when the glass went down and the alignment was wrong so I kept aligning it myself. Then keep pushing the bubbles out lol. Guess I'm lucky even though there's such a big in the middle but without the UV light I can't see it lol.
NeonX
Ya usually when got bubbles and u let the glass down means gg liao, can't squeeze the bubbles out also since the glue will also flow out if you apply pressure
Sent from Google PIXEL 3 using GAGT
laughingPANDA
Yeah man. That gap in the middle of the screen under the UV light probably was glue flowing out after I was trying to squeeze the bubbles out. But heng lah, as long as under normal use it doesn't show can liao. Won't be flashing under the UV light anymore haha
NeonX
The feel of the pixel with a super thin case is unrivaled. But I miss the design of the fabric case haha
teoph04
Other than Spigen Crystal case, what other things cases are out there in the market?
Sent from Google PIXEL 3 XL using GAGT
NeonX
I'm using mnml case
You should try it with a skin bro. It's even better :s13:
Yeah but dbrand shipping expensive since I got a lot of skins that I need,maybe should order ah
laughingPANDA
I'm using mnml case
Hahah yes you should. Alternatively you can go slickwrap website to see see rook rook. From time to time they have like 40/60% off. I recommend honeycomb skin, the texture not bad haha.
teoph04
I'm using mnml case
You bought directly from their website?
