128GB sd card for phone giving problems
Fenrir8080
Hey guys i recently bought 2 types of 128GB sd cards for my Note 8 from Shopee. Both are giving me problems. One is SanDisk ultra class 10 128GB and the other is Samsung 128GB which is a black card with blue text. When I copy the files over to the sd card card, the transferred files go "missing" when i search for it in my phone. When i take picture and save it to the sandisk, it appears as a grey picture with white exclamation mark. Furthermore, when j download netflix shows and save it to the sandisk run into errors.
Is there anyway to fix this issue. I am not sure if i can post the shopee link here. If it is allowed i will be happy ro share it with others so they can avoid the shop.
yusoffb01
samsung dont make black microsd. you bought fake china ones.
Next time buy from lazada local sets with warranty less than $30
namex123
Has i know the higher is 64gb got 128GB? :eek:
upload picture that micro sd card you buy so other people can check for you.
maybe old shocks :D
Fenrir8080
(https)://i.imgur.(com)/EHlNyRj.jpg
(https)://i.imgur.(com)/vok0Jle.jpg
Please remove () from .com & https
maybe old shocks :D
xonix
Doesn't look legit to me...
Elysium87
when a item is super cheap, something is already wrong.
first you should at least do some market check online on what is the average price. check for the actual item online also (like going to samsung/seagate web site to check if there's such item)
second, always look at the review before buying. usually when an item is fake, ppl will comment/post review.
i guess this is a lesson for TS and other ppl. at least it wasn't an expensive lesson.
Rashkae
Might want to post this in the mobile phone section instead - this section is more for PC hardware, the experts on phone compatibility issues will be there.
Rashkae
Incorrect:
https://www.samsung.com/uk/memory-storage/microsd-card/MB-MSBGBEU/
namex123
Chinese New Year Coming Soon You are unlucky
Buy Fake sd card i check that seller luke***.sg
not good feedback from buyer
Very poor product quality. Basically a scam. Memory card only worked for 2 days and all my photos are gone.
What terrible person to be selling this.
i suggest go full refund
look sandisk so weird the card printing :eek:
averdant
You bought fake SD cards where they flash eg. a 16GB SD card to appear as 128GB to your phone. Your files keep disappearing because when you exceed 16GB you get your files deleted to make space for the new ones. There are apps on google playstore that you can use to check if your SD card is fake.
Always buy from authorised dealers when you're buying something that is very rampant in fake china goods circulating the market eg. SD cards, graphic cards
86technie
Can print as if look like real but when use than different story.
Morale of the story for SD cards just buy local stock.
Usually SanDisk will have vendor sticker on it.
yusoffb01
thats a fake 128gb because the 128gb letter is wrong font. and if u plugged in it shows 125gb which is wrong. real ones will show 119gb
Fenrir8080
Thank you everyone! I've learnt a good lesson from this. I have decided to buy my sd card from sandisk official store at Lazada.
