Microphone recommendation
Kamalraj07
I use Audio Technica ATH-M50x headphones. Unfortunately, it doesn’t have a mic and I need one for gaming.
I’m looking around for microphones that can attach to the headphones. I came across on massdrop that they have Modmic (very ex) and Minimic (bad reviews).
Any recommendations for decent mics that don’t cost a bomb? Also I’m not willing to buy a gaming headset..
86technie
Budget?
Can consider getting Creative soundcard that comes
with Mic:
Sound Blaster Z PCI-E Internal
SB Omni Surround USB External
Audio Technica ATH-M50x is a professional monitor for music
so there isn't any optional Mic for it.
Alternate is look for desktop Mic but depending on the price
and brand.
If you want decent one sure be expensive so the Creative
option is your best option. Not to mention with soundcard,
your headphone will sound better than onboard sound.
Kill two birds with one stone but that is of cuz if you
have the budget.
Elysium87
Budget?
with Mic:
and brand.
have the budget.
any recommend sound card for 5.1 speaker ? my mobo doesn't have 5.1
bunnypangsai
Why not get an external mic to complement with your current headphones?
Can consider blue mic.
wwenze
https://www.ebay.com/itm/Clip-On-La...h=item4d6e7970fc:g:prQAAOSwGh5Zy5hi:rk:1:pf:0
Kamalraj07
Budget?
with Mic:
and brand.
have the budget.
Thanks.. It’s nice to have a sound card but unfortunately, my gpu is vertically mounted and would be in the way of mounting the card.
-Synchronicity-
Get creative sound blaster e1. It's a clip on DAC with in-built mic at 49 on creative website. Can probably get it cheaper if you find hard enough on carousell. Got mine at 30 bnib there.
Mic is fantastic. DAC is ok-ish but for less then 50, can't complain. Since it's a DAC you can obviously just plug And play so you don't have to worry about installing additional stuff.
wwenze
Yes! Something like this is what I’m looking for. But of course one with a decent quality.
U buy from AMDK massdrop or kickstarter, they just take the same thing and repackage and sell u USD$20
86technie
External soundcard like Sound blaster omni surround 5.1
with build in microphone.
Just speak to the soundcard.
Psycovirus
Get this from Aliexpress?
Boom mic for ATH-M50x
Kamalraj07
I believe the ideal position to place this would be in front of me on the table. However, it would end up picking up my keyboard noise instead of my voice LOL.
