Replacement lock for Network Box at home
tian800
Hello. Does anyone know where can I buy the lock for network box at home?
cscs3
looks like someone do a easy job using the lock location to pass wire out from box.
eric3743
https://i.imgur.com/IIHWxZW.jpg
Not sure if yours is the same as mine.
The box > https://i.imgur.com/WF7p5Ao.jpg
If you notice that my ISP contractor did the cable pass thru within the wall from inside the box to have 2 ethernet cables on faceplate + 1 telephone cable beside.
As for the 'lock' which may be just a latch in plastic type;
Front > https://i.imgur.com/UWsDYJSl.jpg
Behind/inside > https://i.imgur.com/Kb99ENVl.jpg
Although in front is to twist the round out for to hold on & pull out the whole cover.
tian800
Wah thanks bro. Really helped alot! At least now i know what brand to look for :D
Anyone knows where can I buy this Hager latch?? Not even sure they will sell it as an accessory... Might need to replace the door or even whole box :(
Did a search for their shop online, seems like they are more for corporate rather than consumers.
eric3743
No need to replace the door.
Think the door lock/latch is able to catch-lock in place without any screw or whatever.
Not sure where to get but maybe can try asking those BTO contractors.
