Trueblue82
- Jan 30, 2012
- Always 'out of ammo'. Most of the time this message is wrong, it only means you magazine is out or short of ammo, you have to reload. It may also mean your second weapon (you can have 2 in the loadout and swap between them) is out of ammo, the currently equipped one is ok. Indeed, often you do actually run out of ammo. I think there is some balancing to be made to let you carry more, or get more when you pick up.
fighting boss, the game makes u have to kill his underlings to get ammo, if not u run out of ammo then gg.
cannot focus on boss only.
. Shoot out ice (target seeking) from hand, it has 10 ammo, can shoot in a stream, the cool down is very fast too, so pretty much endless supply of ice ammo (it damages the enemies like bullets, not just freezing them). I only use weapon after freezing enemy, then shoot ice again, or call down lightning with the other hand (ice+lightning is combo move). If teammates work together, I freeze, they shoot, I don't even need to use weapon. When running into turret tower, just shoot all ice ammo will freeze it, then lightning, a few weapon fire, freeze again, repeat, easily take it down. Or use the fireball (separate loadout), go behind cover, charge up, go out and fire at it, go back behind cover, charge again. Basically works like RPG but doesn't consume ammo.
