Hey guys,
Was trying to charge my air-cond, MHI system 3 and got confused.
Pressure was ~100 psi when I switched ON 1 unit, but went up to ~130/140 psi when all 3 units were switched ON.
So, which one is correct?
Just switch ON one unit or all 3 units?
Need expert's advice.
Bro, seriously not recommended to fill gas on own.
1) 410 gas so expensive one tank if dont have many outdoor units to fill, may not be worth.
2) Improper refill gas or tank management can cause air into the system. air, with moisture, is bad for gas system, can cause corrosion and gas leak. air and freon mixture will cause the pressure reading to inaccurate as diff gas compress at diff rates. Hence again not cold.
3) Years of experience tells me that its a experience-oriented task and need experienced tech. i used to be like that and engage cheap aircon companies. The aircon tech overfill gas causing condenser not cold. I wanted to save, end up spending double jobs to request experience tech to solve issue.
Then i found SgOzoneAircon.com 's Keith and i have been using him for years already.
Nowadays, the aircon technician's experiences really counts. There are too many inexperienced tech in market. Keith chatted with me and said nowadays aircon tech so many, how many really know what they are doing? He said he encountered so many aircon not cold caused by gas overfill due to inexperienced tech.
They also had a cheaper chemical wash which can solve aircon not cold issue. Clean is 70-80% compared to chemical overhaul but price is less than half of overhaul. Price is reasonable and i can do chemical wash every year to prevent aircon not cold due to dirt choke on coil. Coil is really easy to choke on new gen aircons.
Share my experiences and experience really makes the difference.
