Xperia XZ Premium - The successor to the Z5 Premium is finally here!
yhw22
Yup, heard like didn't resolve the smart light pop up issue.
Sent from Sony G8142 using GAGT
snowydust
Anyone knows how to disable the update notification from popping up on the screen? I find that this time round the Pie update notification keeps popping up. I almost unintentionally downloaded the huge update while i am outside (accidentally pressed the download button while i was holding my hp)?
vofzxy
do you all stick to the default apps used in your XZP ah?
like video editor, photo editor.... etc
any slow mo video editor to gai siao?
everytime i install a new app
have to keep choosing which app to use for specific task :s22:
freedom-strike
security patch nia
What happens if, for once, there is a system update notification, it is being ignored and nothing done?
My first smartphone being HTC, then switching to Samsung twice, i don't recall getting system update notifications every now & then from the mentioned brands.
86technie
Depend on the Android OS, Android 8 and 9 onwards.
Now they will have monthly security update to patch vulnerability.
Older phones on Android 4 - 7 there is no monthly patch.
Sony have been active to push these updates, I do not use
other Android phones so I don't know about Sammy and etc.
You can ignore but the patch does several things like bug fixing,
performance, add features to it and etc.
Especially if you have issues with the phone, once the patch comes
it may or may not fix it.
Why not do it?
jungle_sg
Anyone has any issue with Xperia Companion? I use to be able to update the software using that but nowadays whenever I open XC, it immediately shut down, I have uninstall and reinstall many times and it is still doing the same thing, therefore I still could not update my software.
vofzxy
today i went to play with the S10+
the video gallery application to view slomo videos id definitely much better then sony implementation, cause the timeline is displayed like the iphone
instead of sony, UI keep coming on and going off
vofzxy
got myself a new ringke case
comes with USB-C and 3.5mm port cover
quite tight to squeeze in
bevan1121
My xzp is having difficulties charging now, swap cable chargers all can't charge unless it's propped at a specific angle. Are there anyy 3rd party repair providers around who still touches sony phones?
