Just Me
- Jan 1, 2000
Works on mi max 3 as I'm using oneCan't get TPG working on Mi Max 3, works on my old Mi Max 1.![]()
Sent from Xiaomi MI MAX 3 using GAGT
Actually anything above 3 is the same.Base on the current official China and Global roms. It is still at Level 4!
I suspect that the upcoming Pie roms (Beta or Stable) might be up to Level 5!
It's *#*#86583#*#* for snapdragon devicesTotally no internet with TPG on MMax 3.
Tried on both Sim Slots, only TPG SIM, set APN to TPG/TPG, chose TPG as Mobile Network.
Chrome just shows no internet and apps cannot get data even though it shows 4G on status bar.
Typed *#*#4636#*#* and ping Google, just shows Fail(2) and HTTP Client Test: Fail: IOException.
Dunno what I'm doing wrong, emailed TPG for help too.![]()
4636 works as a testing code, try it out.
86583 is just for VoLTE, the problem is that I can't even get Internet let alone voice call.
Sorry, just to be sure... Did you save the APN after setting it up?
Did you forget to assign the sim for Internet access?Yup. The TPG SIM card works fine on my old Mi Max 1, just no internet on MMax 3.![]()
On global rom? Its strange that yours doesn't work since we are on the same phone. Mine's even an export set as well. Yours has the 4g icon and signal bars displayed?Even tried with 1 SIM card only, default data/call setting is auto set to TPG. Mobile data on, still bo Internet.
Oh ok.. Then I'm not really sure since I'm on global rom.EU weekly ROM but shouldn't make much of a difference since Circles Line SIM works fine.
Yeah 4G 4 bars VoLTE icons there, just no Internet.
Anyway, I'm always on custom ROM so no problem with ARB. Just interested if it's still 3.
Global, not china? Any OTA update for this? Scared if I update my tpg sim for Volte might stop workingPIE (Android 9) - Official Global Recovery ROM for Mi Max 3!
http://bigota.d.miui.com/V10.2.1.0.PEDMIXM/miui_MIMAX3Global_V10.2.1.0.PEDMIXM_a9972483fb_9.0.zip
You have volte enabled as well! Are you using tpg SIM card?Appeared on my Mi Max 3 now as well! Global rom!
