AFTERSHOCK PC
dereth
Hi, may I know what brand of card does Aftershock bundle in if I select the Zeal with 1060 6gb? Thanks!
Oh, and how long do they typically fulfill and deliver an order?
killtuna
I believe standard is Zotac Mini.
Mine took around one month...
vofzxy
Erm...
My Aftershock just suddenly turned off :-(
Anyone experience this before?
Issit a batty issue? It doesn't have removal battery though
Maybe a thermal paste issue?
Haiz about 2 years old nia
singupingu
Battery? Laptop?
Go to their service center and ask them check for you. Checking is free, servicing is free. Only hardware change will cost if your warranty is over.
Sent from OnePlus ONEPLUS A3003 using GAGT
vofzxy
Battery? Laptop?
ya laptop
ya okay will go down
sunht
CPU (Bolt) : Intel® Core i7-8700 Coffee Lake 6 Core Processor (12M Cache, up to 4.6 GHz)
DESKTOP MOTHERBOARD (BOLT, ZEAL) : H310 Chipset Motherboard
Thermal Compound : IC Diamond Thermal Compound CPU (Free Lifetime Thermal Compound Re-
pasting)
Graphics Card (Bolt) : NVIDIA GEFORCE GTX 1070TI 8GB GDDR5 + 550W 80+ PSU Upgrade
CPU Cooling System (Desktop) : AFTERSHOCK F10 Premium CPU Cooling Fan (White)
Memory (Bolt) : 16GB DDR4 2666MHZ (8GB x 2)
Solid State Drive, Bolt : 500GB SSD
First Hard Drive (Desktop) : TOSHIBA 2TB 3.5 INCH HDD (Buffer Size 64MB)
Chassis Fans : Standard Chassis Fans
Case Lighting : RGB Case illumination (One color can be selected at a time)
Wireless Lan (Desktop) : ASUS PCE-AC56 Dual-band Wireless-AC1300
Operating System(OS) : Windows 10 Home 64 Bit
Custom Cable Sleeves : Standard Cable Setup
Something like this
I'm considering this spec too, can please share what's the manufacturer/brand of the 1070ti and SSD? Don't find them on Aftershock's website.
Thanks.
And by
Sent from OnePlus 5T using GAGT
_DeS__
Thanks.
And by
They are using their own rebranded ssd.
Gpu is zotac.
L3g0la5
Do you guys think that they will have huge promotions soon?
Their promotions are pretty much the same mostly. I bought my MX-15 Pro at the last Comex. The promo they currently have for Tech Show is exactly the same.
Yunzzz
You have any idea how many ppl dunno how to DIY, yet wanna play games. Also, how many ppl wanna get a system from a shop that provide after sales service.
Otherwise, brands like Aftershock, Dreamcore, etc etc won't thrive :s22:
There are legit reasons to get these branded boutique builder system. Warranty, is one of the biggest reason and determining factor. It is cheaper from SLS and online, but you gotta cover your own backside for troubleshooting, warranty and RMA if sh*t hit the fan somehow by bad luck. Money you saved might not be justified if you are a working class and you gotta spend time and take off to send your parts to RMA and another off to collect your parts, as distributors operate at office hours and days.
Hi, seeking experienced advice. I have never built my own PC and I don't intend to do so, only read up on specs a little on Google. Rather pay for a peace of mind so really interested in Aftershock customisable pc. I'm looking to buy Aftershock Zeal which I want to pair with prism plus F270 pro monitor. Need some advice on the specs I need to do justice to the screens 1440p, 144Hz specs. Below is what I'm currently looking at, anyone can tell me if anything is too little or too much or any bottleneck areas.
Aftershock zeal price: $2064
Mother board: Asrock B360 motherboard
CPU: i5 9400f
GPU: Rtx2070
RAM: 1x 16gb ram KLEVV
240mm Aftershock glacier water cooler
256 ssd
1tb HDD
Aftershock Rgb strip
Aftershock Rgb fan
Power supply: 600W fsp hyper k psu
Wireless lan: Asus pce ac56 dual band wireless ac1300
Window 10 home 64bit
arfness
CPU: i5 9400f
GPU: Rtx2070
256 ssd
1tb HDD
Aftershock Rgb fan
I was just looking at the exact same setup for my friend. I think it is perfect. Good Price with great specs for a full pre-built machine with a warranty too. Maybe a i5 9600k for the 4.6ghz boost, but i think the 9400f will be good enough.
snowsakura
CPU: i5 9400f
GPU: Rtx2070
256 ssd
1tb HDD
Aftershock Rgb fan
1x16gb ram not that good.
Go for 2x8gb ram
Yunzzz
Oh the 9600k is quite a bit more expensive may I ask what's the difference?
snowsakura
Because it can overclock.
But it have to use “z” series motherboard.
If you don’t mind you can have a read up on ryzen amd cpu then decides.
Btw ryzen 3000 series is around the corner.(if you don’t mind waiting).
janeow
was thinking about getting their bolt red recommended spec model. is it any worth it? really lazy to deal with warranty etc if i build myself from amazon.
-AMD RYZEN 5 2600 | 3.9GHZ | 6 Cores 12 Threads
-ZOTAC NVIDIA GEFORCE GTX 1060 3GB GDDR5 AMP CORE
-16GB (8GB x 2) DDR4 2666MHZ
-IC Diamond Thermal Compound CPU
-INTEL/AMD stock cooling fan solution
-256GB M.2 NVME SSD (Read Speed 1200mb/s | Write Speed 600mb/s)
-TOSHIBA 1TB 3.5 INCH HDD (Buffer Size 32MB)
-Standard Chassis Fans
-Standard Cable Setup
-500W EVGA 80+ Bronze Premium PSU
-Windows 10 64 Bit SL
invigo79
You forgot to put the price.
Sent from Home using GAGT
