Durian Shell
- Jun 26, 2018
If that was the case then it should be included in the firmware as the "auto update" by right should not occurred in the first place as mentioned by them. I have already updated the firmware to the latest but it was still happened. It was made by hardware malfunction issue and therefore it is not a feature. They just handed another set from the bunch that they normally would to another customer for exchange.
You flashing new firmware, the auto update image is still there, LPPL..Already explained, need to remove/disable the auto update image.....
By the way, I'm happen to use this feature
