In short, yes. Need to have a neutral wire to somewhere (ultimately to DB)Thanks for the diagrams,
so if my current switch doesn't have neutral wire, i need to pull 1 from the DB first?
Sent from HUAWEI BLA-L29 using GAGT
Yes.Regarding neutral wires, is it right to say you only require it if using smart switches?
For Eg the Xiaomi ceiling light seems like no need for the neutral switch and I just need to leave the normal switch in the ‘on’ position?
Yes.
It is to keep the smart switch powered to keep its functions.
Your Xiaomi ceiling light is powered as you kept the normal switch on.
Technically it's the same.
ER....
hdb only running 1phase in ur own dwelling
different phases neutral is for 3 phase pwr and you dun have that in ur own dwelling, unless u stay in landed bunglow
either u buy 2c+E or just buy twin core cable, where when u split it it will have a N and a R.
N will run back to the N-bar
Earth goes back to Earth bar
1 N cable will terminate at Earth bar
Load to Load
Active to Active
without Neutral, behind the switch usually is labelled as 1C2 or 123, where 1 or 2 is the common and C is the live
Thanks! So what exactly would be the benefit of using smart switches over smart lights? Other than more colors![]()
ER....
Load to Load
Active to Active
Hi thanks for the explanation, appreciate it greatly,
then the neutral wire from the switch i must pull to the DB then connect to which point of the DB?
Also as iamnagel was mentioning, would it also work if i just tap the neutral wire from the ceiling point and bring it to the switch instead? without doing anything with my db?
thanks for your help
some switches do not need neutral like Xiaomi Aqara switches (they have both types btw)
but some question its reliability. Im using these myself and a few had broken down after about a year but does that mean a small batch is bad or is it a complete design fault - that we dont know yet. Only time can tell.
Switches saves more money - one switch can control a few lights and you can use any kind of bulbs and fixtures, basically your existing ones.
Smart lights are more costly and they connect via Wifi which means nothing works without an internet connection. Smart bulbs reliability are questionable too just like an ordinary bulb can easily konk, so can these. They also often goes offline for whatever reasons
There are neutrals at the light points so no need to pull anythingI am contemplating to do smart lights for my new place. Was quoted $60 to pull neutral wire and change each power point excluding any hacking if necessary.
Is the price reasonable?
Seems more hassle free and only cost $18 more per light with the added ability to change between warm and white light. Am I missing something?
Ah yes sorry if im unclear.
The light switches are just going to be simple malia legrand switches for now. So there is no termination point.
Hence the electrician is saying could be unsafe.
Only at the switch points there’s no neutral.
If smart lights are more economical for you then use that. Everyone’s situation is different I guess
Ya. The price quoted was for light switches. I’m still in half mind whether to change the switches or the lights
Only at the switch points theres no neutral.
Change at switch is better. The problem with changing at the bulb means the switch must always be in the on position. Really confusing when someone turns off the light with the switch and you try using your app or voice to turn on the light. It will not work then you need to get up, walk to the switch and physically turn it on.
Posted from PCWX using Me dic stinks
rinse and repeat the basic wiring theoryI'm confused. Isn't it just tap neutral line from light point and fish it down to the switch? Why need to buy 2 core wire and split into 2?
What gauge to buy for neutral line?
Posted from PCWX using ALP-L29
Neutal to Neutral
Load to Load
Active to Active
so that everyconnection is closed loop
no bar, use a strip, there is sth known as N strip or E-strip
Thats why i am not an advocate for 100% smart switch. i prefer a smart switch w contingency. where automation is an given option. but without automation it still can function w/o electricitysome switches do not need neutral like Xiaomi Aqara switches (they have both types btw)
TBH all these automation not quite suitable for HDB. for landed thats a different story
u can have solar, u can have UPS battery back up for 4-6 hours
There is nth wrong to play with it. but from my professional opinion, it is really more of a expensive hobby in hdb settings
