because nvidia shield
haha you got a point. yeah may be they get paid to write bad reviews.
Also in US, Mi Box S got tough competition from Roku and Amazon FireTV Stick 4K.
Ref:
https://www.tomsguide.com/us/xiaomi-mi-box-s,review-5985.html
In Singapore context, Roku is not so useful. Amazon Fire TV Stick 4K is not too bad in Singapore but lacks of Chromecast support.
Complaints about Mi Box S seems to be focused on Video and Audio output quality and the auto detection of TV resolution.
But considering the price, nothing really beats Mi Box S if you either need Netflix or Chromecast in the Sub-S$100 range or even sub US$100 range.
For people who are willing to pay, NVidia Shield TV is the way to go.
I think you can sideload apks into both the Fire Stick & Roku. If so, it’s not bad a choice considering it’s direct plugin and powered via the tv.
The only way to install viu on mi box s seems to be downloading it to a USB drive and install it on the box using ES file explorer (or some other file explorer). For launching it, need sideload launcher too. Would have been better if at least it could be launched directly with default android launcher but android just seems to have stupid restrictions.
Anyway my mi box s was working very smoothly so far with no issues at all. I don't understand why there are such mediocre ratings about it on the internet.
Possible to install mouse or keyboard? Find it hard to use to remote?
Any helpful apk for me to install into app? Mainly news programs
can get a bluetooth mouse or keyboard if you don't want to mess with USB dongles. I'm using Logitech k400 plus keyboard + touchpad combo on top of the given Bluetooth voice remotePossible to install mouse or keyboard? Find it hard to use to remote?
It is not necessary to install if you can chromecast from phone.
If you insist to run it from box, use tv repo app or atv launcher site to generate the icon on leanback launcher.
bought xiaomi box s bout one mth ago and it has been working well
However few days ago the UI suddenly becomes very laggy, even load the movie oso it stutter
Other than reset the whole box, any other recommendations?
https://s.lazada.sg/s.3m8A
Offer for Mi Box S at S$65.99. Normally it will run out fast. This Lazada shop will have this type of offer from time to time.
Thanks for the link!
Can I check, Mi Box 3 and Mi Box S are the same model?
No. Mi Box S is the international version of Mi Box 4.
Older Mi Box Global version is kind of international version of Mi Box 3 (or more similar to Mi Box 3S).
Ahhhh I see. Coz when I clicked on the link you shared, it says Mi Box 3. Just want to clarify if it’s the same as Mi Box S. Thanks for explaining!
Sorry I said wrongly it is Mi Box Global version and not Mi Box S. It should still be very good but try not to upgrade from Android 6 to Android 8 if you can. There are quite some complaints about the Android 8 upgrade.
This one is Mi Box S but at higher cost. It comes with Android 8.1.
https://s.lazada.sg/s.3mIS
In terms of hardware specifications and function, both are almost exactly the same.
I think it's ok to upgrade the mibox3 o/s to 8.0 already.. there has been a couple of firmware updates since the major one that caused issues to some users.. in fact my own mibox3 didn't encounter any major issue since updating from 6.0 to 8.0Sorry I said wrongly it is Mi Box Global version and not Mi Box S. It should still be very good but try not to upgrade from Android 6 to Android 8 if you can. There are quite some complaints about the Android 8 upgrade.
it isn't impossible to downgrade Android o/s version but it can be very technical and complicated on a non-rooted device especially if you are an iOS user..I see. I’m an iPhone/iPad user, so can I check if it’s possible to downgrade OS on the Android platform because it almost impossible on iOS.
And one last thing, you’re advising Mi Box S and Mi Box global version are good enough, but Mi Box 3, not so much, am I right?
