Encrypted11
- Jun 9, 2012
Preface: This thread is created as a user discussion to highlight the characteristics of Hynix CFR/CJR based memory kits for both Intel & AMD platforms and how they can be a lower cost alternative to Samsung-B kits. Feel free to share your hynix c overclocks with manual tuning!
Seems like 4000MHz memory is no longer limited to samsung b and e die based sticks, Hynix C does it at a significantly lower cost.
Hynix C-die is one of the latest revision of DDR4 SK Hynix ICs (4th gen). It is the only available IC from Hynix that carries a JEDEC DDR4-3200 bin unlike hynix a-die which stops at around JEDEC DDR4-2933. Select modules carried by G.SKILL, Corsair, Kingston, Klevv and a couple of other enthusiast memory makers do sport the Hynix C chips. They're also availabile locally due to lower costs unlike Samsung-B kits.
The special characteristic of Hynix C are that they only operable with relatively loose timings compared to their peers from Samsung. However, you can make up for most of the latency and timing related deficiencies from these ICs at high frequency. As such from a performance standpoint they'd work best with Coffeelake and other platforms derived from Skylake when paired with a motherboard of decent caliber (S$300+ typically with 6 layer + PCBs) due to the brute strength of its memory controller.
A small writeup from Jagat OC is available here (Sniper X 3600 is also Hynix C based).
http://oc.jagatreview.com/2018/07/h...kill-sniperx-ddr4-3600cl19-16gb-kit-2x-8gb/2/
