iPhone Xs, iPhone Xs Max, iPhone Xr Accessories Thread
audioenslave
Any1 using wireless charging dock for Apple Watch 4 n iPhone XS Max?
Any reputable ones to recommend?
Can Samsung duo charging base charge the Apple Watch series 4 n XS max?
blurnard
I believe is doable...
I am using this in my office. But only to charge iphone XS..no apple watch to charge.
*adiBOY
Not at all since Apple Watch charging technology is proprietary though the underlying tech it uses is still Qi.
The cancelled AirPower was the only Qi-certified charger able to charge the Apple Watch. Oh well...
Lucky177
I’m using Okonz privacy. Generally ok. Smooth. No sensitive issue. Full coverage. But not fingerprint free. Easy to wipe off tho’.
Anyone can recommend screen protectors that's from qoo10 that you have good experience with for the xs max? Thanks.
FeNgZhEnG
any TP that wont chip so easily??? i dunwan spend on expensive TP but yet still chips:s22:~
jq75
Im using a spigen all round protection. Only accessible part is the mute switch, which i use on and off. And maybe i snack and touch the mute button, now there is slight discoloring. It was worse, but i use a eraser and it is better now.
can mute via assistive touch button functions:D
Elijahonli
Ordered this for around $12
MFI Ugreen Lighting to USB-C PD 1MCable
