8-lane
- Jan 29, 2013
both are free
Wah that's something..
both are free
Data can be used in Malaysia
However on roaming on
digi you get 0kbps,
Maxis you get 0 to 1mbps. (Can use but unstable)
If you need data you need to set it as maxis. Data seem to be very unstable. Just in case, having another SIM might help.
redONE still have to improve on roaming.
jus tested data roaming in malaysia. must set to Maxis. u will get LTE.
speed quite decent able to use whatsapp call along NSL from Muar back to JB with no lag and load fb and instagram fast.
however digi only gets 3g connections and the speed is pathetic. so my take is jus switch to maxis manually when u r in malaysia
Starhub.
10 char.
How about every month go to shop and pay?anyone tried signing up with a virtual credit card at the shop? i wanna sign up for my grandma but dont trust them with my CC number to be honest
In Singapore if they lease starhub line then it should quite stable.
But in Malaysia if only can depend on Maxis for data roaming then it failed.
Any sim card or registration fees to pay for?
Is there monthly roaming subscription fee?
Malaysia telcos are this pattern, even China rural 4G network better than them![]()
