I just want to know, which is better to use in Taiwan, in terms of usage and cost.
I am not sure to get the wifi router or get the actual SIM card when I am destination.
Thanks in advance.
Thanks in advance.
on qoo10, you can get 5days unlimited sim card @ $6.90 only
excluding singpost $0.80 for every 2 pieces
https://www.qoo10.sg/item/ICC-ICC-T...ALL-FREE-INCOMING/457040715?banner_no=1305330
Sometimes in the train the wifi router might lose signal. Not sure about the sim card.
Tried WIFI router once, cannot connect halfway trip, end up buy SIM cards over there......... suay
Wifi router has another problem, if fully connected by 5 pple, battery will run out very fast, need to prepare powerbank, even with powerbank, the router might die off in the evening around 6-7pm, cant last till 11-12pm. And every night need to charge both the router and powerbank in the hotel.
The upcoming trip, i will get sim card.
found wifi router to be unreliable at times, prefer sim card
to be fair... i think most of the wifi router issue arises due to the Fair Usage Policy if you use over the daily limit...
just make sure the provider you get from ensure unlimited data... sometimes although it is unlimited... there might be a need to reset the router to reset the limit again...
This is cheam.
But not all wifi router is unlimited, all depend on country you go. Place like China, wifi router don't work well.
Even if the wifi router plan is unlimited data... it still can be bounded by the FUP implemented by the local service provider... means if u over use certain data limit... the speed will be capped... but u still can use at a much slower speed... so best check with the provider whether the country u go to have FUP...
From what i know taiwan dun implement FUP...
https://www.changirecommends.com/owifi_specs.aspx
