Xiaomi TV Discussion Thread III [consolidated]
m/mink
Yep precisely, if these estores had solid Q&A sections (like amazon perhaps), people won't need this forum..
I'm guessing both stores didn't give you the answers you need?
You're completely out of topic now with your reply.
Buying $336 (from Qoo10) instead $499 (from Carousell) would result in the failure of a store because people are not willing to pay for services and answers, wasn't it?
How does that work?
maddyks
Am I misunderstanding anything here?
Qoo10 merchant is an estore, with a warehouse/shop in IMM
Carousell seller is also an estore, with a warehouse in Link@AMK
Both would answer questions if you have any.
The only difference is their price difference of $133 upfront. $366 vs $499
Carousell seller has unspecified delivery charges while Qoo10 has -$30 voucher and free delivery, that stretches the disparity even further.
I am curious about that voucher :D
petetherock
Moderator
Moderator
How does that work?
336 is a very good deal, if he sell for that price, go for it! Thumbs up!
Big savings :s47:
maddyks
Mine schedule to deliver tomorrow. I got mine from Shopee $389 within tv bracket. Looking forward to this 4k tv. I also bought the Xiaomi Sound Bar for $89 too:)
My existing Amoi 26 inch lcd tv has white patches all over the screen, use for 10 years liao, time to change as buying the polarising film from taobao to change myself seem difficult:s22:
Review? :)
dricas_007
Got my Xiaomi 43 inches 4K with Xiaomi Soundbar today.
Never ask properly tv really come with bracket but no installation.
In the end use my drill and try to drill the stupid cement wall, drill one hole nia damn shag and sweating lol. But its too late so drill another day when I am free. Quicky find a temporary spot and setup the tv.
Overall I am satisfied with the quality, sharp and clear. But dun know why the spdif from tv to soundbar no sound lei. Select the sound output to spdif also cannot. In the end choose connect by Bluetooth then it work.
I love watching drama show so I install the 今日影视 apk using thumb drive copy to tv direct and it work :D:D:D
RVS_SK
seem like the one year warranty provide are not onsite, you have to bring the bulky tv (i ask only about the 65inch one) to their store for repair.
anyone here use the 1year warranty to repair their xiaomi tv before, can comment?
m/mink
Bluetooth connection will have noticeable sound lag right?
maddyks
Thank you.
Are you using it as your main TV or guest room?
pcuser123
Hey can an expert tell me which xiaomi model is the most high end one? I only care about picture quality, not the smart features. Also prefer thin bezel. Thanks!
Sent from Google PIXEL 2 XL using GAGT
The MiTV4 (without any subscript, MiTV4A or MiTV4x) is the higher end as it has faster CPU and GPU and slightly more expensive..As for picture quality, cannot compare to those which has IPS Led panels, all MiTV4 has TN Led panel which does not have as rich picture but TN is a faster panel for games. MiTV4 supports HDR (high dynamic range) in a way that it will play HDR pictures but not displaying it.. so the picture coloring is not as rich as those HDR TVs. Besides these, it is a good quality TV minus the higher price..
pcuser123
There should not be any sound lag if the bluetooth devices are properly paired.. make sure there is no other bluetooth devices nearby that could cause interference and also, the memory caches are always cleared without any residual "rubbish"
pcuser123
The SPDIF should play unless it is faulty.. you might have to select both, the TV and the sound bar, to SPDIF output in order to play. These selections are not automatically selected.. using a multi-meter to measure if the cable has electrical continuity; it might be broken.
lolipop
Thank u!! Finally something very useful for reference. All I can Google are discussion from India which is quite confusing...
maddyks
I am thinking of buying the 43" but worried after talking to a few friends that it might be too small. They all suggest 65". Does anyone use 43"size as daily TV?
dricas_007
Later when I reach home will try with another cable. But this cable is new and come with the tv :s22:
m/mink
It all depends on your personal viewing distance.
Mine is 1.2m, so 43".
Tony_Chua
Audiology93
Living room or bedroom? If living room, 65" is better. If bedroom, 43"
Sent from Samsung SM-G975F using GAGT
