Guys! You all got DIY clean your aircon blower ?
mkaung2000
mkaung, there is a PCB on the right side.
When the FCU is on the wall, are you sure there isn't any need to remove the PCB? I think the PCB is blocking the top right screw.
Furthermore, is loosening the 2 screws on the right side enough to pull out the blower? Don't need to remove them?
Are you able to take out just only the blower without the back chasing is unscrew the 4 screw?
Sir, when are you going to clean Aircon again? Can invite me?
Hi, yes. Just remove the 2 screws at the left and loosen the 2 screws at the right.
And, loosen the set screw on the blower, you can slide out the blower easily.
I'm not sure if I want to invite you for air cond servicing.
But, I will try to take more photos and post it here.
LouisSaha
Maybe gonna try get the karcher vario 360. I already have karcher 2 compact used to wash car. So i guess this vario 90 deg can fit my karcher 2.
Saw a few pages back, maybe i go get the multi purpose cleaner. The ajax one good? Hope it cleanse well. Will coil look silver after using the ajax or mr muscle cleaner?
Mecisteus
I'm 200% sure. You do not need to remove PCB and only need to loosen the screws at right side.
I did many many times for my 3 units.
Thanks bro.
I will check again probably in the next 3-4 months.
Please do take more photos. Before and after blower is out. :)
Mecisteus
what is the usual period to service the aircon? every half yearly ok or not?
It really depends on your usage behavior.
If you rarely use your aircon, you don't even need to service regularly.
As a gauge, look at the blower of your FCU. If there is a pile of dust there then it is a good time to clean it.
Just like when you clean your ceiling or standing fan, you will see if there is a lot of dust or not.
Bare minimal, at least clean your filters regularly.
koganei123
fan coil unit is the one outside?
ipaq4444
thank you Sir, i face problem removing hte blower even after taking out the screw that connect the blower to the black colour thingy.
Can ask how you remove the FCU? do you need to cap the pipe before removing it.
ipaq4444
thank you Sir, i face problem removing hte blower even after taking out the screw that connect the blower to the black colour round thingy.
how come your fcu pipe is so long able to let the fcu rest on the floor? d oyou also remove it to wash at the toilet?
Mecisteus
FCU is Fan Coil Unit. It's the one indoor. This one must be clean regularly.
The outside one is compressor. This one doesn't need much attention. If you like to clean, just spray water.
Mecisteus
I have seen the contactors dismantling my FCU.
A lot of job has to be done. Even though I am a technical person, I wouldn't dare to DIY myself.
I will get another contractor to do a chemical wash in 2-3 years time. By then, my aircon is 12 years old.
Kudos to mkaung!
By the way, did you manage to locate the 4 screws?
virtualape
Kudos to mkaung!
i would suggest to change the aircon system.
older system consumes more electricity. over a span of a few years of savings from purchasing a new system vs paying more for electricity, it may be the same.
i was using a tickless system and switched to a 4 ticks. electricity saved 50% (approx $120 per month). system 3 and is turned on daily for 9-10 hours.
better off getting a new system and enjoy it.
Mecisteus
My MHI has 5 ticks I think. I have been using the same aircon settings (23C) and number of hours ever since. My electricity consumption has been relatively the same though out.
The system has broken down once only due to dirty FCU. Otherwise, my aircon is as good as new even though I don't expect it to work 100% brand new because of aging.
If the aircon is maintained clean and has no problem, the aircon can still serve well. I disagree on changing the whole system.
mkaung2000
Here is the procedure how to remove FCU.
https://forums.hardwarezone.com.sg/119593230-post2585.html
Chemical Washing Procedure.
1. Pump out gas form evaporator [FCU and piping] into condensing unit and lock[close] service valves [These valves are at outdoor unit]. This is called gas saving.
This is tricky part. There are a few steps and you need to be careful.
If not, you will lose gas and need to top up.
How to save gas?
- Switch On the indoor unit which you are going to clean in cooling mode for 5 mins. Then, you need to go to outdoor unit. You can feel the air coming out from fan at outdoor unit was a bit warm. That means compressor is running normal.
- Close the service valve at discharge port [at the outdoor unit].
- Let the Air-Cond run for ~3 to 5mins. You will feel the air coming out from fan at outdoor unit become cold. That means compressor is running without gas. Condenser coil is not hot anymore.
- Close the service valve at suction port.
- Switch Off the indoor unit.
2. Switch off the main Air-Cond circuit breaker.
3. Disconnect flare joints [2 copper pipes], electrical wiring and drain pipe from FCU.
4. Dismantle the FCU down from the wall.
5. Dismantle the electrical circuit board, evaporator coil, drain pan, fan motor and fan blower.
6. Tape up flare opening of evaporator coil, to prevent water going in while washing.
7. Bring FCU coil to washing bay, flush with water and spay chemical. Use alkaline chemical [Not acidic chemical].
I bought 5litre bottle @$15 from Daikin. I think ½ litre is more enough to clean 1 unit.
The chemical solution will react with the water and the dirt to cause a forming process. The forming process will extract dirt trapped deep inside the parts.
8. After soaking the coil for about 5 min, flush the coil with water to remove all residual chemical solution.
9. Wipe dry all parts and reassemble the FCU.
10. Clear the drain piping at the wall with vacuuming or flushing.
11. Install the FCU back at the wall. Secure the flare joints, connect the electrical wiring and drain pipe.
12. Purge out the air from the FCU and piping. Proper way is to vacuum out. But, I don’t have vacuum pump. So, I just purge out. I think even those Air-Cond guys don’t use vacuum pump.
Purging is done like this.
- Loosen the joint at suction pipe.
- Open [a little] the serve valve at discharge port to let some gas out from already loosened suction pipe joint.
- After a few second, tighten that joint.
This is actually illegal [in US] as you cannot let CFC gas out into the air. But, I think all the Air-Cond guys here do that. :s22:
13. Unsecure[open] both service valves and test for leakage at FCU flare joints. I use Elitech WJL-6000 gas detector.
14. Switch ON the main Air-Cond breaker
15. Test run the air conditioner and check gas pressure.
16. Top up gas if needed. Usually, you won’t need it.
ktyandkyc
The FCU has a blower. Blower is like the rotating fan blades.
Shine a torch light and see through.
If there is a pile of dust, you need to clean them.
Mine at service yard further away from window. Isit rly require lesser attention for outside unit?
Sent from Xiaomi REDMI NOTE 5 using GAGT
Mecisteus
Yes. Outside compressor supposed to be durable and long lasting. Imagine it's exposed to the weather conditions. So just spray water will do.
The FCU is the one that requires more attention. Especially you are breathing the air coming out from there.
pohw0008
My aircon at mbr not as cold as before.. it is also quite clean on the filter and fan coil.. i could hear the sound diff from the other aircon.. also the wind blow out not as strong.. could it be the gas is running out? Should i just do a chemical overhaul with gas top up? Thanks..
LouisSaha
Check ur blower
Mecisteus
If gas, the other FCU will not be cold also.
Buy a cheap anemometer to check the actual temperature of air blowing from the FCU. It should read <20C.
How old is your aircon? Frequency of cleaning?
