kenapa siol
- Dec 12, 2011
It wont be plug and play. at minimum, will still need to run the “setup wizard“ which would be step by step.
if it's your first time, 30mins - 1hr should be enough to get your network up and running using default firmware and basic settings.. most of the process is just click next next next..
Thanks for the replies
Regarding the China or local set, the same applies and it doesnt affect anything as in running the setup and click x 3?
