Lian Li TU150
Rashkae
It was only announced 5 days ago and is not widely available. Even Newegg still only has it on pre-order.
If you spent 5 seconds on Google, you can see that Corbell is the local distro. Go ask in the Corbell sub section.
zhihao57
Yea.. I know ma, thats why asking WHEN, not WHERE. Can't seem to enter the newegg preorder site anymore, not sure why.
Was thinking if anyone know roughly when it would reach Singapore's market.
Don't need so fierce leh :s22:
koroshiya8
Nowadays technical forum getting quieter.. partly due to much information can be found online.. and market is so small locally you seldom get proper and robust conversation here.
Encrypted11
Wonder how Dan D Z who got Lian Li to OEM his Ncase M1 feel on the case launch.
So Lian Li made a case that looks Ncase M1-ish :s34:
Maybe Daniel Hansen's A4 is next, hopefully they don't go with the path thermaltake did :crazy:
hg2
Will get it if it's Dan's A4 dimension, too bad it's only slightly smaller then NZXT 210, too big for my likings....
Terminatrix99
I have spoken to Corbell on Facebook and they have placed orders for the case. However, no delivery date was set. From what I see online most are saying end Sept for availability around the world, so probably for SG also I guess.
ragnarok95
Senior Moderator
Senior Moderator
Ncase still more sleek le. :o :o
xonix
[ YOUTUBE]N5O6WZKERZ8[/YOUTUBE]
The fact you can install such big coolers inside shows it's definitely bigger than dan a4.
It's more of a "mini" mini tower
hg2
My poor sense with image size :s13:, as i can't tell a 120mm vs 140mm fans from pictures. Also, no idea how big a CPU cooler fan can get, as i never play with one for more then 10yrs...most people can't tell a 15" rim from a 17" ?:s13: would easily assume the left cooler can mount into the right case....
This case design "hint" very similar to ncase m1, and was under the impression that its a SFF category case. Hard to tell from pictures, unless placing it side-by-side with other cases....
Koenig168
It's about double the volumetric size of the M1 - 23.7L vs 12.6L so quite a bit of space inside.
zhihao57
Yes ah! That's good news! HAHA
zhihao57
LAI LIAO LAI LIAO, I saw one post $165, at carousell. By techronix or smth haha,
It states "COMING SOON"
