Mouse with no left-side buttons (minimum gaming)
Shahmatt
I am looking for a mouse preferably without the left side (thumb) buttons. These buttons I never use except to accidentally press at the worst time.
Would like to have good gliding and DPI control down to at least 800 so that I don't have to deal with too much sensitivity.
I don't play much games except TF2. Mostly business use.
Any recommendation is appreciated.
Psycovirus
I remember about this mouse, Asus ROG Pugio.
Able to use the included covers to remove the buttons on the sides.
There might be other mice, but I can't recall atm.
Koenig168
You can use the mouseware to assign a function like "mute" to the left thumb buttons.
Shahmatt
Yes. A bit lazy to reassign actually.
But in general I can also never press the side buttons properly. Just the way I hold the mouse I guess.
Considering Logitec G300s. Less than $30 from Taobao.
maniamcool
just go popular/challenger and get a 30 doller mouse off the rack, those kuching kurat mouse all confirm only got 3 buttons, left right middle.
t258jgn
Tecware Torque PRO RGB Gaming Mouse w PixArt PMW3360 Sensor, True 12000DPI
Only $30
I think left side buttons not assigned by default
silentears
if u dont mind side buttons
1 for 1 now can get on lazada g102
i using it notch bad, can disable the button with software? i never try but i think might be possible.
most impt is cheap
Phen8210
Which mice u used that u accidentally press side buttons? you might have encountered a few blacksheeps, try not to let it limit your selection!
Buy a cheap $10 mouse and then use your screw driver and remove the left mouse button using brute force.
haylui
Are you sure about this? Go to their website the mouse seems to have side buttons just like others.
http://www.nordicgamesupply.com/accessories/mionix-avior-black
Not the Avior with numbers behind
dgenex
Just disable the side buttons or get a non-gaming mouse. Otherwise you are limiting your selection for no real reason if your only problem is accidentally clicking onto the side buttons.
Almost all gaming mice you can just unbind the side buttons with their software
Sent from Xiaomi REDMI NOTE 7 using GAGT
msaz
agree i bought a less than $10 mouse at challenger , no thumb button. sim lim also got sell like those on sale $4 hp type mouse literally thrown in a box. level 5 near escalator can get one.
12122012
86aa6ba66c0867634a9287f490bf840c
https://shopee.sg/Alcatroz-Wireless-Airmouse-2-i.9372692.664890169
been using this mouse for all my PCs... during promo just $3.90...
