iPhone Xs, iPhone Xs Max, iPhone Xr Accessories Thread
Glariel
Every screen protector full coverage or what will trap dust.
If you want no dust that is not possible. Don’t put pocket is the best. I noticed when I put pocket will attract a lot of dust
Ya the gap is bigger than the spigen ones but spigen also have a gap so also will trap dust.
iCarez no gap but will trap at the edges. However can only see when you remove the glass.
I have used iCarez full coverage and also spigen but sway and cracked them. Nowadays all quite expensive so I decided to try the cheaper ones.
jq75
clothes, cloth fabric
Lance321
Does anyone know of any local shop selling this VRS design "damda high pro shield" iphone Xs case? I think this new version looks very nice and striking. I contacted qoo10 VRS design official shop, and they mentioned that they don't have it yet, so I was wondering any other local shops have this case, or have you guys encountered any other local shops selling this case?
Link from VRS design USA site:
https://vrsdesign.com/collections/i...high-pro-shield-series?variant=22603658199158
https://vrsdesign.com/collections/i...high-pro-shield-series?variant=22603657904246
Melvyn_
Thats weird.. How come mine got no dust? :s13:
Cloudj13
Hi,
New Iphone (XS) user here :)
Anyone use Okonz tempered glas (bubblefree full glass) before?
Is it worth it?
Compatible with PSAJ case?
Kindly share if any :)
Thanks.
Cloudj13
I recently bought 2 from qoo10, I think it is comparable to spigen ones and cheaper. If you don't mind can try.
I also saw another one, will be trying if the current one breaks.
Hi, which model you bought?
Any problem so far?
stjl000
Ya or if you chinese noob like me can try ezbuy, now they got some ezgadget. I saw cable as cheap as $0.70 and review not bad.
vbhelper
What privacy filter brand is good?
Most privacy filters I used still can see from the side very clearly
bbbbbw
First time I drop my xs when getting out of the car. Was holding the phone in my hand and using the same hand to close the car door.
The rock brand case had a dent at the corner but the phone condition no damage. Cheap brand cases can be good too
Hitokirii
My rhinoshield solidsuit become loose nowadays .
Anyone experience the same ? Reaching 1 year of usage
Is a good casing nonetheless.
Hope the price will drop after new iPhone release
Glariel
Loose? For which iPhone??
My XR a bit lose, for XS and XS Max quite tight
Hitokirii
For xs max.
When newly bought , it is extremely tight . Need to use bull strength to pull out the phone from the casing .
Now it become v loose already . Should be wear and tear after 1 year
Glariel
Not really
My iPhone XS is the most tight. Last year put in already want take out difficult to take out until I have to use force. Luckily phone no problem
No . At most only remove twice to clean phone before . I think it auto expand. The plastic cannot tolerate the tightness
