Thanks Shiny.
I guess the simple conclusion even if I thought that GBP which is "low" at the moment and foresee GBP will strengthen, I still should not look at ETF that is in GBP currency. So just stick with IWDA which is in USD currency.
Exactly right.
Hello Shiny!
1) I plan to invest about $500/month. What would you suggest for people like me who just started working can only invest small sums but want to buy SPDR Straits Times Index ETF? The only other alternative I see is POSB Invest Saver, but it does not allow me to buy that particular ETF.
See below. Unfortunately Maybank cancelled the MIP a few weeks after I published the 2019 edition, which is a bit annoying... I like to think they got crushed under the weight of new signups.
2) Additionally, I have a student loan debt incurred from CPF (2.5% interest annually) loan, which I plan to pay about $1000 per month. Any opinions on the ratio I am allocating between my loans and my investment?
I'd pay that one down as slowly as you can. 2.5% is a very low interest rate; you want to take advantage of it.
If you are using POSB IS and IBKR, it doesn’t matter if you split into 3 funds or lump sum into 1 every month, right?
You wouldn't use those two in combination, though. IBKR's $10/month minimum monthly brokerage makes it too expensive for small investors; and POSB IS's 1% fee (with no minimum) makes it too expensive for large investors.
Small investors (under $1k/month SGD, and under $100k SGD total account value): use POSB IS for local stocks and Stanchart for global stocks.
Large investors (over $1k/month SGD, and/or over $100k SGD total account value): use Stanchart for local stocks and IBKR for global stocks.
I am a complete beginner and am looking to start investing 2k every month into ETFs. I already have all the pre investment fundamentals covered i.e. 6 months emergency fund, debts and insurance. I saw that the recommended choice is between the POSB Invest Saver and the Standard Chartered Brokerage. Would the advise be for me to use SCB due to the lower fees of $10 compared to POSB's $20?
If you're investing $2k a month (or any amount over $1k), the recommended choice is "Stanchart for your local stocks (ES3 and MBH), Interactive Brokers for your global stocks (IWDA)".
The lede of the article is that this guy has discovered that US equity returns back in the 1800s were lower than people thought. That has absolutely zero effect on how you should invest today. You can ignore this article.
a) In this example, we are trying to find out how much is the monthly contribution to achieve 1 million at age 65 for 35 years of savings at 7% return on investments. Why is inflation factored in? Inflation will be factored in only if we are looking at required expenses at retirement but here the inputs are only 1 million, 35 years and 5%.
b) I checked the bankrate.com website but couldn't locate the calculator used for the above computation. Could you please direct me to that calculator?
1a) The inflation-adjusted return on investments is just the "nominal" return on investments minus the inflation rate. 7 - 2 = 5.
2)
This one'll work.
2. You advised to invest in STI ETF (ES3). In the past years, that ETF returns has been pretty low. Will you still advise to invest in it now?
Yes, for two reasons:
1) You're going to retire in Singapore, so you want exposure to the Singaporean economy and Singaporean cost of living. The best way to do that is Singaporean stocks.
2) Stock markets (not individual stocks, note!) tend to be cyclical. Markets that underperform eventually outperform. The US stock market is trendy right now, but that won't last forever; emerging markets will have their day.
3. For the Bond ETF, you suggested MBH instead of A35. A35 has higher liquidity compared to MBH. Will A35 be a better option?
No. MBH would generally have higher returns over the long term, because it has a higher yield for relatively little extra risk.
4. Page 44: You mentioned using MayBank KE to invest in local Stock and Bond ETF. MayBank KE is a regular savings plan where a fixed amount is contributed every month to purchase the ETFs. How will we do rebalancing if we are using MayBank KE since we cannot sell a certain portion and purchasing of the ETFs is done every month?
Delete "MBKE" for "POSB IS", but otherwise - you basically have to change your POSB IS allocations in the month where you rebalance, then change it back.
5. I plan to invest $500 every month into the 3 ETFs. IWDA is currently ~ USD 57.68 (SGD 79.62). If I use Standard Chartered, brokerage fee will be USD10 which is ~3% of total amount paid. That is high. Will it be better that I invest $1,500 every quarter instead?
You should generally be buying one counter every month - whichever one you're short of compared to your target allocation. So it'll go something like:
Month 1: ES3 or G3B
Month 2: IWDA
Month 3: ES3 or G3B
Month 4: IWDA
Month 5: A35 or MBH.
If you do that for five months, you'll be at an 80/20 allocation. (If your target allocation is lower - say, 60/40 because you're 50 years old - you'd buy A35/MBH in more months, and ES3/G3B/IWDA in fewer months.)
