Samsung Galaxy Fold
thesettingsun
bonus question: yes and no, if you open the multi app tray you will realise that not all apps are available for selection, however as a workaround those app can be open on the main half display instead
Thanks. Just a follow-up on that - does enabling in Settings "Developer Options - Force activities to be re-sizable" help to force all apps to work for multi window? What if we select an app from the "recent apps/overview" button and then select "open in split screen" if that app does not appear in multi app tray, would that work?
berber
nope, force activities to be re-sizable doesn't enable all apps for multi window and the recent app won't display a "open in split screen" option if it's not a compatible app. let me know what apps you have in mind, i can help check if its compatible.
"yes and no, if you open the multi app tray you will realise that not all apps are available for selection, however as a workaround those app can be open on the main half display instead"
^ also, for this workaround to work need to install good lock + multistar first and enable the "enable multi window to all apps" option
Cantabiles
thanks! where can we get a screen protector for the front screen? even when the armoured cases finally come out still need this screen protector right? didn't see anything about this in the thread yet.
Apparatus
Have lah. I have already applied it. It's a plastic screen protector.
Go to XGear at WaterPoint@Punggol to get it
thesettingsun
Thanks much, can I trouble you to check on these apps pls?
Tradingview
Discord
Google keep
Amazon kindle
qw_er_ty
Gonna recontract with singtel. Those who wish to buy galaxy fold can PM me for details. Thank you.
808ster
Sim Lim square level 5 also got a shop can customise
Cantabiles
just bought already! screen protector and rear camera protector. i didn’t the fold out cos i scared. should i attempt to apply myself or should i bring to let the shop do huh? they asked me until i scared to do myself
808ster
They doing a great Job. Don't have to worry. For the front will require to heat for the corner to seat in nicely. Not easy to apply own self
cueball1981
Anyone experience like no data link but signal show lte 5 bar. Have a friend who also experience this on singtel. I'm starhub
Sent from Samsung SM-F900F using GAGT
Gaminator
Yes, I'm on Singtel, when I get into a lift, and upon getting out, my signal strength shows full after a short while, but no net connection. Sometimes it comes back on its own, sometimes turn off mobile data, then turn on again to reconnect to mobile network. Best result is to restart phone.....
