Comparison of SIM only plans
Jurong640
My 2 year M1 contract finally up
Thinking of going to Singtel’s GOMO for $20 20GB data or StarHub’s giga for $25 25GB data but can rollover
The rollover data means what ah?
If month 1 I use only 5GB
Month 2 I will have 45GB?(25GB from Month 2 and 20GB rollover from Month 1)
Also I have a SurfShare attached to my main line
Can I port out my main line and SurfShare directly or do I have to convert my main line to SIM-only then proceed to port out?
Thanks in advance!
you can port out directly if it is under the same name. Gomo 30GB is for first month only, thereafter 20GB/mth.
If you need more data, sms and mins, M1 sim-only will be the best choice. 30GB data with 1k sms and 1k mins. If you got safra member, you get 35GB.
Roaming will be better on m1. Gomo still does not support voice roaming.
galaxyuser
M1 better. Can choose to add on 10GB, 50GB or 150GB for 10 dollars, 20 dollars or 50 dollars respectively.
barnabaskoh
My wife just ported out of m1 because she says time to time cannot receive reception to send data.. And I have been reading she is not the only one..
squarepipe
https://www.vivifi.me/vivifi_lite/
Yihaoong
Redone benefits more
- free Malaysia roaming (per per roaming for other countries)
- unlimited 128kbps data
Vivifi benefits
- more talk time (500mins)
- data roaming to most country
Wow can rival for redone $8 per month plan
VaNs
Changed from Singtel to Grid.
Delivered on 23rd Oct and activated today.
So far so good!
Posted from PCWX using Pixel 2 XL
squarepipe
Want to subscript this plan for my mum due to 500 talktimes free incoming, she using prepaid sim now. Always buy the $128 value top up card which cost S$26
But she asked can trust or not? Never heard before, wait closed shop how?
Sent from Mercedes-Benz E250 using GAGT
Keep the prepaid SIM. Sign up a free TPG line for unlimited calls. It's not like you can port prepaid number to postpaid mvno
josh123
Has anyone terminated their home fibre broadband in favour of unlimited Sim only plans? My place currently have some dead zones and it happens to be the bedrooms which suffers.
Rxgn
Vivifi use which main telco network?
Think is singtel?
Sent from Samsung SM-A705MN using GAGT
