OK, let's run through these items....
This account is currently paying roughly 2.5% interest per year if you've reached the 12th counter month, assuming Citibank doesn't change the rules which it could at any time. (Also, as the one month SIBOR fluctuates, this account's interest rate does, too.) I assume this account is your emergency reserve. Of course if you actually withdraw from it the interest rate falls.
This one doesn't make much sense unless you're expecting some large ~$20K bill to pay when it matures. You're dragging rather a lot of cash already in that Citibank account.
This fund is a "target date" fund, which would be quite nice as a separate matter if you allocated all or nearly all your long-term investment dollars into this fund. The major problem is that it has a typical unit trust cost: a 1.22% annual expense ratio. That's not good.
OK, that's kind of like your fixed deposit. At this point I should say something like, "Great portfolio, Grandma."
Using the CPF Investment Scheme, I assume. It's icky. On top of the CPF Investment Account costs, which are awful when you're buying monthly because there's a charge for each transaction, you're paying the fund manager's fee of 1.44% (annual expense ratio).
If you and your spouse don't need all your OA dollars for housing -- and you do have relatively a lot of cash sitting around, I'd point out -- then you can transfer some or all of your OA dollars into your Special Accounts, up to the Full Retirement Sum. Your SA earns at least 4%, possibly 5% if you haven't yet maxed out bonus interest. That's way better than some expensive CPFIS unit trust.
After your SAs have reached the FRS you might take a look at the CPFIS for remaining OA dollars, but not with that unit trust.
This is also a bit on the expensive side. You can do better.
What's BIP? Do you mean BCIP (Blue Chip Investment Plan)? If so, what's it going into?
And what do your respect MAs look like at this point? Are you both making $7,000/year SA top ups for tax relief? (I'm assuming your spouse's SA is still below the FRS.)
