Changi Sim Card for Thailand
Cartoon0512
Hi, never try the above before as normally we bought from bkk airport at 299baht. Anyone tried or use the above? Is $5 only .. isit hard to activate it ? Thanks
Andrew833
Just plug in and use, no problem. $5 for 8 days :D
Jeremy1
Yes and need to call *120 to activate the card B4 use.
So far this is the best bargain.
If cannot connect when reach Thailand, can go to the AIS booth and ask them for help.
Cartoon0512
Once I call to activate meaning the wifi (data) also can use?
BlackCube
Don't think need to call. I never call before. Just plug and plug. That was some time back.
Posted from PCWX using Pixel 3
ericwilis
The price is 5 dollar if u book online.
On the spot is 6 dollar.
I just use it. Pretty good except personal hotspot(tether) keep dropping after 3-5 mins, but that could be due to IOS issue rather than carrier issue
Andrew833
Can book thru whatapps.
Cartoon0512
U buy n collect it from airport on your departure date ?
Andrew833
I book few days before, then collect on the day of departure. There are many counters in each terminal, so don't have to worry much. As long as you rem to collect before you walk into transit area.
Cartoon0512
Ok noted . Thank you so much .
Jeremy1
Actually it was stated here :
https://www.changirecommends.com/deal.aspx?id=965&gclid=CjwKCAiAjNjgBRAgEiwAGLlf2oeECMsSAaeolg326MLSwokhupwOnv1-W4QjNNBZh234c9aLUjGESRoC15YQAvD_BwE
I think you can tried not to call and c can work when reach Thailand Airport or not or you can check with the staff at Changi Recommended Booth.
