Samsung Galaxy Note 10- Let's speculate...
DigDub
any suggestion how to set a good quality sound ?
Sent from Galaxy Note 10+ using GAGT
It depends on the earphones you use. Use Adapt Sound feature, it improves the sound quality.
doki81
new Nov fw update is out for odin :) ..but only on security update..
samgoh87
Hey samgoh87 and keladin,
Can i know if you have samsung health (to count your steps) and face unlock turned on?
I have this 2 turned on. I wonder if it is contributing to battery loss.
Thanks.
Not using Samsung health at all(think I uninstalled it as well) and using pattern or finger sensor unlock instead~~
xenocide
not sure can bring to Samsung to have it check or not.
wireless charging is not charging also sometimes,
so not sure whether it's due to hardware or software.
i left it to charge overnight, sometimes it's full charge next morning, but like this morning, it's stuck at 20% thru the night.
i experienced this lately also
initially was fine. every night can achieve 100% next morning
recently it keeps breaking charge at less than 50% and won't charge any more
kinda frustrating to wake up with a uncharged phone
lcheowl
if after using another charger and charging wire still the same, then confirm the battery issue.
You should bring in for servicing.
noblewolf
I second the adapt sound feature. Our ears are unique to us, different people have different auditory sensors and some frequency ranges audible to younger people but not to older people. Adapt sound exploits on that. It measures the frequency range audible to you, the owner, then creates a custom profile based on the results of the listening test. You just have to be honest whether can you hear a sound being played or not.
DigDub
Yes. And best thing is that the custom equalizer and adapt sound settings applies system-wide so that there is a consistency in sound quality for all the apps. Unlike other phones which relies on individual apps settings which applies to that app only. Sometimes users complain about "bloatware", but some of them are actually useful.
Samfreak
I just learned about this feature (Adapt Sound) from you. Tried it and it works well!
Thank you!
WangsKy
Is there a way to stop apps from moving when using the task manager? Always accidentally delete the wrong app.
