AirPods Pro (Beware of fakes, buy direct from Apple!)
softbunlet
How many of you bought apple care+? Worth it?
Seems worth since Airpods Pro are expensive to start with. My G1 battery life went down to only 40min-1hr near the 2 year mark. Will do a battery service just before 2 years for the Pros.
ngcw81
But it’s your g1 battery status show below 80%? They only change if less than 80 right?
ngcw81
I think u can check on iPhone when u open up the case if the AirPod show how many percent on battery... I guess by this way.... some expert can advise on this?
actually how do they check if the power holds less than 80% ? Im also debating abt the apple care lol
BlueBull
Just bought AppleCare+ for my APP online. All you need is your APP serial number. Very easy and fast.
Red Nails
Are we allowed to return in store if we purchase online arh..??
Tot of giving APP a second try even tho I sold mine alr :o
leongws
Collected the APP at jewel a while ago. Opened it up in store and wore it after the staff taught me how to pair it. Paired and immediately can feel the ANC at work. Toggle between transparent, off and ANC to feel the different and it’s very noticeable. Will try it out with music later on.
slowchemical
Do feedback whether u have the exclamation mark bug with the APP that many are facing .
tohchr
Do feedback whether u have the question mark bug with the APP that many are facing .
Mine also had the exclamation mark error but somehow it does not affect performance nor charging. Hence, I will be waiting for firmware updates as I strongly believed it due to iOS 13.2..
