MrAwesomeX
- Sep 27, 2015
No cheap and good PSU like last year?
Between CORSAIR Vengeance LPX Ryzen Certified 16GB (2x8GB) DDR4 DRAM 3200MHz and Crucial Ballistix Sport LT (2x8GB) 3200MHz C16 DDR4, what would be the better choice? (Or just go with the cheaper one?)
If you are willing to tweak to oc your ram(and use ryzen where memory speed makes a diff), get the crucial ballistix sport LT. I've got mine oc'ed to 3800 cl18. This set of ram uses Micron Rev E die which are pretty overclockable.
Edit: just got on desktop and saw your rig :/ . Applies to others with ryzen systems tho.
Hi, any 400-500w psu on sales? No need too good cos its for my media pc
Sent from Samsung SM-G950F using GAGT
first one is amazon.com using SGD currency conversion
second one is amazon.sg
sorry if this sounds lazy,
let say if theres any issue, have to return. is the process straightforward by contacting amazon CSO?
ps, this is my first time buying on amazon..
Did you buy any ram to upgrade your new laptop? Aiming to buy kingston hyperx since it is cheaper than crucial one.You can contact CSO, or just press return on app, print ninjavan label and drop at any ninja points near your house. You have 3 months to return. Mine is just provision shop downstairs
Armageddon from lazada?
Okay thank you! If I buy from the application is okay right? No differences right?
Anw, anyone got Amazon promo code? I tried a few but it doesn't work.
R their PSU even reliable? I rather go get FSP or etc budget ones.
Mlmlwml. Their own pc also use their 900w psu. Their 500w is like 250wArmageddon from lazada?
any idea where to buy the cheapest 120 or 240gb sata ssd, no need m.2.
