Xiaomi TV Discussion Thread IV [consolidated]
RaptureM3
Bought the 55" Global version from Lazada on 12.12 for $479, TV finally arrived today. Russia model as most others here have gotten. So far so good, only the digital channel searching turned up no channels. This is the latest 4S suppose to have DTV tuner built in.
When i search for channels, should i choose "Antenna" or "Cable"? Both turns up no channels though. Will reach out to the seller for help.
RaptureM3
It works (able to find the digital channels) when i plug in the external DTV tuner. Not sure if the DTV tuner built into the TV is too weak or not there. According to listing this latest 4S should have the DTV tuner built in though.
Another thing i notice is that the patchwall keeps saying "Internet not connected" - could be because it is a Russia set (geo-block) as YouTube, etc works fine.
Anyone else got their set yet?
yanfxl
Just got the Mi 4A 32 inch.
How do I switch audio track for Channel U? And how to enable srt subtitles when playing movie from thumbdrv?
Any help appreciated. Thx.
whoooo
Center (enter) button in the remote, more option, system setting, channel, audio track...
Yes very difficult way to change track and subtitle as xiaomi using google live tv over which is not very user friendly
whoooo
Unfortunately the tv Dan tuner is quite weak ,u may need to use usb powered antenna
Patch wall go to page 53
Hoo8899
Guys, what is the difference of the global version and the taobao version? Are the Xiaomi TVs digital ready?
jtec14
Correct me if I am wrong, even with built-in DVBT2 tuner, you still need an external antenna to work, same as any local TV set with built-in DVBT2.
Aside to RaptureM3, your seller MU TV Store from lazada? Waiting for mine to be delivered.
1a2a3a
Hey man, can let us know which seller from Lazada?
Also, is it A55 or A53?
2gb/8gb configuration or 1gb/8gb configuration?
Yours come with patchwall instead of android?
RaptureM3
Wow, thanks all for the prompt replies!
Been reading through last night, seems like bro @jtec14 is right, internal DTV tuner doesn't mean no need antenna, still needs!
After i plugged in the USB antenna all the channels appeared and they gave the DTV antenna FOC so all good. Would have preferred a 'cleaner' install tho.
Thanks for the patchwall link. Seems many have issues with this also.
Taobao is china set with china OS, language in Chinese until modified and no Play Store / Google apps. Can sideload APK though but that's troublesome for me so i went with the Global version.
Yes MU TV Store. PM them and ask for the courier's phone number. I called and 'chased' him and he delivered the day after i called. Just tell him your address and he will tell you how many slots down you are in his delivery list.
Actually i just checked my chat - the courier's number is 9 6 seven nine 6 5 five 9. Let them know you bought the Mi TV from Lazada and they can advise.
Thanks about the antenna info!
This link:
https://www.lazada.sg/products/digi...html?spm=spm=a2o42.order_details.item_title.1
Listed now for $629 tho. 12.12 flash sales went down to $479.
2Gb/8Gb
Model number L55M5-5ARU.
Not sure what is A55/A53 sorry, where to check?
The TV is Android TV 9. Even the Global (Android) sets come with Patchwall.
Let me know if anymore questions!
P.S. TV so far so good, can't complain for $479!
P.P.S. Figuring out why my Netflix doesn't display 4k titles..... I am playing through Mi Box S, have a 1Gb connection, and a 4k TV, but still only playing in HD (1080p). YouTube is OK for 4k videos though.
RaptureM3
Btw, Global Android 9 sets also no Netflix for Mi TV. Just take note. You will need another streaming box (Nvidia Shield, Mi Box S, etc) as i understand Mi did not 'buy the license' from Netflix or something like that.
FYI you can install AIDA64 or CPUZ to identify the CPU, to see whether it is quad core Arm Cortex A55 or A53.
A55 is newer than A53 but in reality the difference is not that big for Mi TV.
whoooo
Not truth only the Russian 4S android 9 dont have the native Netflix, spanish 4S w Android 9 comes w Netflix support.
Check the hdmi adaptive setting, not at home but I rem there is a setting
cochran
i installed AIDA64 & CPUZ on my 43" 4S 4K russian set. The resolution reported by the software is 1920 x 1080p
So its 4K or full HD only? software bug?
RaptureM3
Will check tonight and update.
Thanks for the clarification!
Will look into the HDMI adaptive setting. Appreciate it!
Mmm will check mine tonight too but mine's 55" not sure if there's any difference. My YouTube shows as playing in 4k though.
RaptureM3
Btw i have 3 ports on the Mi 55".
HDMI 1 (normal)
HDMI 2 (ARC)
HDMI 3 (normal)
I plugged my Mi Box S into HDMI 2 (ARC). Is this correct? Any difference whether i use an ARC or non-ARC HDMI port?
Yes, do not look at the screen resolution from the app. Only look at the CPU info and Android info.
kelvinkezz
Anyone having issues with the YouTube app that is preinstalled in the Xiaomi tv? Thanks
ABuNeNe
does the global version mivt with android tv comes with vp9 that plays 4k video?
kelvinkezz
