tk
- Jan 1, 2000
Any tyre for smoother quieter ride?
Sent from Xiaomi MI A3 using GAGT
Bridgestone GR90 or Michelin XM2 are good choices if available in your size
Any opinion on pirelli p7?
Also looking for cosmetic repair. Deep scratch. Any recommendations?
If deep scratch on tire sidewall better change the tire
Ya.. saw everyone says Bridgestone T005A is it really that good?Bridgestone T005A
Im letting go of mine if you are interested! Feb 18 model. So far, personally there is no problem with the car. Not too sure about other common problems tho.What are the common issues for Elantra 2016-2018 gls model?looking to get a used one.
Sent from OnePlus GM1910 using GAGT
why selling when it is still quite new?![]()
Looking to change to freed or sienta as need additional seats (got kid and parents to fetch).
sienta hybrid ba![]()
Anyone changed their remote control battery? Did you guys went back to KMC to change it?
Yes, it will indicate on speedo from understanding.
