Comparison of SIM only plans - Part 2
hereiam7788
Sure or not?
cruizer_ph
yep no issue with Circles $7 promo back during 11/11. the estimated bill looks iffy but the actual amount charged to my card when the new month rolled in was all correct. so far no problem with them.
lbguan
M1 coverage actually quite ok. So far I can use it inside the Port and mrt trains without drop calls and can surf the internet fast. ST for unknown reasons the Data bundle actually depleted very fast compared to M1.
Ported out from M1 Sim only. Previously had the same mindset due to the benefits, then I had issues with their coverage in several places.
Couldn't load apps to clock member points, couldn't load ibanking app to do payment, delayed messages, repeatedly lost connectivity, people call in can't hear me... Etc etc...
Decided enough is enough and just port out and fug those benefits.
Sent from Sent From My Mjolnir using GAGT
galaxyuser
Because Singtel counts in data blocks of 10KB. M1 and Grid Mobile counts in data blocks of 1B. By that standard, it will theoretically mean Singtel data will deplete up to 10000 times faster.
twosix
how about the data blocks of the other telcos?
Arandalo
wackykid
regards,
wacky
BusteR
i have 2x M1 sim(3) 1 year contract end 12-Mar-2020 at $20/mth.
i want port to giga $18, will I get penalty from M1?
can i sign up giga but ask starhub start 13-Mar-2020 ?
Giga $18 for 20gb will be back (12-16feb)
dodongdodong
You can sign up and ask for later delivery. Activate after your contact
lohsenglte
mySIM 3 20? Convert to the no contract sim-only plan now, tomorrow plan change then port out on 13th.
mySIM 3 plans change to no contract sim-only plans no penalty.
semap1972
The sim-only plan u mentioned is the 30GB, 1000min +1000sms which oe can convert using the M1 app?
BusteR
my MAX monthly usage for past 6 months:
- 3.58 GB local data
- 171 min outgoing talktime
- 16 SMS outgoing
Is Giga telco cheapest for me?
5GB Base ($10) + 100 min@($1) = $11 /month
meekiatah
myMAX monthly usage for past 6 months:
- 16 SMS outgoing
Seems like. That's why the $10/5gb plan is so good. Very suitable for low data users.
cruizer_ph
yep, good experience with Giga too... if VoLTE is not a deal breaker for you, it's the most cost effective plan for you
