小米AIoT路由器 AX3600
uncle_josh
Too bad miss the boat for ¥599
6 core Qualcomm IPQ8071A
signal amplifiers are installed in the 2.4GHz band and the 5GHz band
OFDMA improve wifi transmission efficiency
WPA3 next generation Wifi security standard
mi app to notify new/unknown user connecting to your network
One SSID , DUAL Frequency
Source : https://www.mi.com/r3600
tan1688
can cover 2 football field ? wah this 5GHz microwave frequency so strong can cause cancer, leh place in your home. Go google no bull shiat
manyu882
Taobao is around $130+
If you plus shipping to sg maybe add another $20
alex22
Humongous log of a router...
Like 2x asus ac1200G put side by side
uncle_josh
Not for the faint hearted xdd :s12:
5G (5th Generation)uses ultra high frequency between 24 and 90 gigahertz frequency.
Whereas Xiaomi uses only 2.4 & 5 gigahertz frequency,
Hate to use Taobao nowaday, always force you to sign in
Also there is always double charge on the courier fee, one internal, one external.
A lot of sites selling at US$139.99 or (SGD199.88)
Indeed , it is very long
For Superior heat dissipation to ensure stable operation
The fuselage uses a large area aluminum alloy heat sink and high thermal conductivity thermal adhesive
manyu882
Take a look at this listing, quite popular. Cheapest to send through ZT快递 for free(SF Express expensive but is much safer as they really take good care of your parcels during transit) . Send to ezship (ezbuy)warehouse and freight forward to SG.
If you all interested Just sound out your interest here and I see if it is possible to do a small MO.
https://m.tb.cn/h.V5pjKVt?sm=e86ad0
SPEED
Anyone using this router in sg already?
Planning to get 1 from taobao and ship to sg via ezbuy
singdiyer
If you wanna try out WIFI 6, you may consider TP-link XD3020, can buy from Taobao also, JD was always out of stock.
uncle_josh
Good News
Does the Xiaomi AIoT WiFi 6 Router AX3600 Support MESH Network?
After the release of Xiaomi AIoT Router AX3600, many consumers are concerned about whether the latest Xiaomi router supports mesh networking. Xiaomi officially responded that mesh networking is supported in hardware, but this version of the software is not supported yet and will be upgraded to support Mesh networking in the future.
Source : https://www.gearbest.com/blog/tech-...fi-6-router-ax3600-support-mesh-network-11527
SPEED
Looks like no 1 in sg is using it yet?
i can assume the menu of the router should be just all in Chinese
uncle_josh
Good question. I also would like to know.
I don't want to dive in so early mainly is to see the feedback on this router.
Sent from 今天工作不努力, 明天努力找工作 using GAGT
uncle_josh
Xiaomi AIoT Router AX3600 features and specifications
574Mbps 802.11ax 2 × 2  2.4G
2402Mbps 802.11 ax Wi-Fi 4 × 4 5GHz
Its independent AIoT antenna also adopts 2.4GHz+5GHz dual-band design, which can provide 150Mbps+433Mbps co-583Mbps rate for AIoT devices
Protocol: IEEE 802.11a / b / g / n / ac / ax, IEEE 802.3 / 3u / 3ab
1GHz quad-core IPQ8071A processor + 1.7GHz dual-core NPU
512MB RAM, 256MB ROM
6 external omni directional antennas + 1 AIoT antenna that automatically connects to Xiaomi smart devices using app
MU-MIMO technology allows multiple antennas of the router to serve multiple devices at the same time offering the best experience
 Up to 238 connected devices
Real time monitoring, parental controls with Mi WiFi app on Android and iOS
Aluminum alloy heat sink and high thermal conductivity thermal adhesive, cooling holes on the top, bottom and sides for heat dissipation. A metal part is arranged on the triangular top surface to accelerate the heat transfer from the inside to the outside
WPA3 next generation of Wi-Fi security standard
Dimensions: 410 × 177 × 134mm
3 x 10/100 / 1000M adaptive LAN ports (Auto MDI / MDIX), 1x 10/100 / 1000M adaptive WAN port (Auto MDI / MDIX),
7 x LED indicators (SYSTEM indicator x 1, INTERNET indicator x 1, network port indicator x 4, AIoT status indicator x 1
uncle_josh
overcomes the thick walls
https://www.xiaomitoday.com/xiaomi-mi-router-wifi-6-aiot-ax3600-router/
octane99
Anybody bought XM AX routers yet?
I am very tempted. But my main concern is the UI, I can't read Chinese.
