cpfis - should we consider sti etf?
KeytoFreedom
I've been holding for 10+ years. Every year, the dividend outperforms the 2.5% CPF interest rate plus capital gain.
The STI ETF dividend was even higher than my housing loan at 0.98%+SOR...
What is the return on STI ETF?
Sent from OnePlus ONEPLUS A5010 using GAGT
thekang
Look forward to the CPF "Lifetime Retirement Investment Scheme". It appears to be a better version of STI ETF for CPFIS. No news on the progress currently though.
w1rbelw1nd
I have around 100k in OA and 50k in SA, after keeping aside the min sum, which I am not going to use for any housing needed.
I dont want to keep them in OA to earn 2.5%, but would like to deploy in market for long term for 15+ years
So my questions are,
1 is STI ETF likely to generate 7-8% CAGR (gain + dividend combined) and one is the best performing instrument to invest with OA/SA funds?
2 What other options can be also give comparable returns as STI ETF? I had studied the performance of unit trusts and seems only handful of them can give more returns than ETF (when we calculate ETF returns with capital gain and dividend reinvestment together)
Appreciate your inputs on this.
1. I dont know the returns can hit 7-8%. It is an index, so it is likely that certain funds outperform it. Moreover, our rubbish STI is only 30 companies, representing a small part of what can be invested through CPF, so thats not a fair comment to try to make. I invest in it because it has relatively cheap expense ratio at a decent liquidity with not the worst diversification. I rather focus on low cost than past outperformance,
Btw I am doing less than 0.2% weighted TER including my expensive high yield bonds (0.5%), emerging market ETFs.
2. Can always do a bit of stock picking if you want. Some unit trusts have good performance, but I dont believe past performance is a good predictor of future performance.
Anyway, more people should lobby for better investment options for CPFIS. What we have in Singapore is sh*t compared to what other developed countries have. Its embarrassing. Screw the 2.5%. We want and can take the equity risk and return.
b107mm
i thought limit is 30% of OA for Stocks
you mean for ES3 can buy up to 100% of CPF OA balance ( less the first 20k ) ?
BBCWatcher
Yes, you're allowed to do that. Above the minimum S$20K retained in your traditional Ordinary Account there are only limits on the following CPFIS(OA)-qualified vehicles:
35%: individual (less diversified) stocks, property funds, and corporate bonds;
10%: gold.
