Redmi K30 Series, Pro and Ultra
mankind66
How to use gift cards? Don't understand
For $800 phone, i buy $800 gift cards to get $16 cheaper?
Please help. Never use gift card before.
Thanks 🙏
eddy0505
Non pro lowest 6/128 config from finer 580 after coupon GC n cc Rebate. Not bad
Nakedtoes
As long as price below rrp is consider good plus shipping is free. If u get from oversea directly shipping going to be killer.
Computeron
now i believe, opened a few apps will take up around 4gb liaao.
6gb is still enough but will it lag? few yrs back 6gb is gd 8gb overkilled.
now i think 8gb is the "just nice".
will see tonight poco's price.. but for sure will be cheaper than now q10's -$50.
scarli end mth -$100 coupon also cheaper than poco's launch price.:s13:
Nakedtoes
6gb sweet spot lar.. Unless u lock some apps always in background.
For poco f2 the leaked price is about or abit higher then k30pro. I expected to see poco f2 same as k30 pro non zoom edition with likely 5g and NFC chip remove if the price is going to lower then k30pro..
Computeron
i see my current usage like 4gb... haven run games yet.
davidwong
Bro unless those apps at least a few apps are games if not it will never reach 4gb la unless you are counting the base 1-2 gb used by the android system
Nakedtoes
K30 pro battery life is dammed good been getting consistence 12hr SOT...:eek:
