Redmi K30 Series, Pro and Ultra
kkfa2018
K30 pro battery life is dammed good been getting consistence 12hr SOT...:eek:
Maybe its becoz not using 5G? Anyway may I know why the purchase of this 5G phone when Songapore no 5 G yet. Was told maybe another 2 years. Of coz, getting new toy is always good.:s13:
Nakedtoes
Cause got extra $$$ so buy to play lor... can simulate economy also:D but frankly speaking if u ask me... i would said my older k20 pro is more then enough and good enough.. :o
NightRaven49
The only thing is does f2 pro and k30 pro has any band differences if don’t have just get k30 pro eu version? Or if adventurous get the cn version at 2999 rmb
missing band 20 for k30 pro, means if go europe will have poorer connection. for sg use is fine.
1c3_5n0w
now i believe, opened a few apps will take up around 4gb liaao.
6gb is still enough but will it lag? few yrs back 6gb is gd 8gb overkilled.
now i think 8gb is the "just nice".
will see tonight poco's price.. but for sure will be cheaper than now q10's -$50.
scarli end mth -$100 coupon also cheaper than poco's launch price.:s13:
I still think 6GB is enough.
From left to right are devices with 6,8 and 12GB of RAM. 6 is enough (dare I say even more than enough) for 90% of users. RAM is meant to be used, more free RAM isnt necessarily a good thing.
I have a V30+ with 4GB RAM and an SD835 too but I dont see the need to add it into the comparison unless y'all are curious.
The devices in the pic are:
- poco f1 (6/128) snapdragon 845
- k30 pro (8/128) (lpddr5x + ufs 3.1) sd 865
- s10+ us unlocked variant (1tb) sd 855
Sent from Samsung SM-G975U1 using GAGT
Nakedtoes
Actually if the phone is 12gb ram and the OS is smart enough to utilize the ram then is even better. Else u can lock more frequently use app in memory
1c3_5n0w
im not a heavy user so it doesn't matter to me. my ram is already utilized well and what i usually use isn't killed
Sent from Xiaomi REDMI K30 PRO using GAGT
mankind66
I check the 5g bands of a few new 5g phones in sg, different brands use different 5g bands
K30 pro = 1,3,41,78,79
P40 pro = 1,3,5,28,38,41,66,77,78,79
S20 ultra = 1,3,5,7,8,28,40,77,78
Mi 10 = 1,3,41,78,79
Wonder what are the 5g bands the local telco will be using?
Hope the 5g phone we have matches the bands that the telco are introducing in order to use 5g 🙏
davidwong
Seems like common bands are 1,3,78.
Hopefully sgp 5G uses these 3 bands
Nakedtoes
Just recieved this nice and smooth case. Very nice feel.. Loves it..
Nakedtoes
Should be different from the free k30 pro cover even though both are black
Yeah the default given case is a bitch to remove and is hard plastic which will crack over time... this new case is tpu mix with hard material time and it protects all around the phone with parts above the temper glass so when u place down the table will not touch the screen... easy to install and shock proof when drop. Yet same feeling as the case given:D
1c3_5n0w
Is the default launcher good
Anyone try poco launcher 2.0?
i stayed on the default launcher for a bit before switching to nova. its not that it isnt good, its just i use nova across all my devices
Nakedtoes
Many years ago i am fan of nova and apex launcher.. Now default one is good enough..
