Almost 8hr SOT still have 40++% battery..
just manually set your ip settings to static and can define your own dns without the use of a vpn.You running constant vpn on? I have the cloud flare 1.1.1.1 app turn on, the vpn took quite abit of battery
Adguard....You running constant vpn on? I have the cloud flare 1.1.1.1 app turn on, the vpn took quite abit of battery
By trendmicro?Adguard....
i enable volte can call... sms i nv tryDo k30 pro have any problem with tpg?
Sms and landlines call no problems without using the tpg app?
By trendmicro?
adguard by adguard
is it free? does it eats your battery and slow down the internet?
I'm using 1.1.1.1, it slow down the speed.
i must say that this Redmi K30 has too many variants, even for the non-pro model has 3 now, all similarly priced:
- Redmi K30 4G
- Redmi K30 5G
- Redmi K30 5G Racing
The mint Redmi K30 5G Racing looks nice![]()
- Redmi K30 4G
- Redmi K30 5G
ask abit, if I were to buy the k30 4g version n install google myself hor
map, banking app and sms etc can use normally ma?
Sent from Xiaomi REDMI NOTE 9S using GAGT
sure why not
thx u thx usure can, i've bought the mi 10 pro, china rom set, easily installed google. All banking and google pay and even for transport works.
No sideloading needed
Other then the camera apex diff. What the biggest trade off between k30 pro and k30 pro zoom ? I am quite interested hmm
Sent from Huawei Mate 20x using GAGT
If u go finer and check price different between both model is only $30.. so not worth to get non zoom..
basically non zoom is having macro lenses... zoom have OIS and x3 optical zoom lenses... so yr pick.. but if u get 128gb 6gb model the non zoom is using DDR4 and UFS3.0 istead of all other models using DDR5 and UFS3.1![]()
