The only hurdle she encountered was to choose which type of set up we need to choose;
1) Modem with router and
2) Modem-Router.
For Singapore fibre ISPs, usually is Modem-Router mode. If you choose modem with router, the app will instruct you to remove the router and use Velop as a router instead. So after choosing Modem-Router mode, just connect the Parent Node to the wireless router and it will automatically acquire DHCP from your main router.
Hey, thanks for the review. Can you help me out with 3 questions please?
Question 1) If I use a modem with router setup (which I believe means a ONT + Router setup), then do I need the router to be present for Velop to work?
So in my current setup it is like this:
Modem -> router
I want to check if it is possible to do this:
Modem -> Velop master node -> Velop child node -> Velop child node?
Question 2) I saw some users earlier in the thread doing the following:
Modem -> Asus router -> Velop master -> Velop child -> Velop child
What is the purpose of the Asus router being there? Seems like the Velop master has to be physically linked by Lan to Velop master. If so, it appears to me that the Velop Master is acting as a router also in addition to the Asus router?
Question 3) What is the rule of thumb you use for arranging your velop devices? Someone in the thread mentioned max 1 wall between them (based on drawing an invisible line between the nodes). If so, this is going to be hard to implement in my unit...
Thanks.
